2/2 Aluminum UF Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2010, 03:22 PM   #1
2/2 aluminum UF cable
What is max amp for a #2 Aluminum Underground cable (with no conduit) as a feeder line ?
I have had and received varying info and feedback about this.
MeanGene is offline   Reply With Quote
Old 06-23-2010, 06:45 PM   #2
Licensed electrician
Rewards Points: 1,630
Using the 60 degree column of Table 310.16, #2 AL is good for 75 amps, before any derating is applied, if needed.
Old 06-23-2010, 06:54 PM   #3
Rewards Points: 1,596
Doesn't cable length possibly change ratings?
bob22 is offline   Reply With Quote
Old 06-23-2010, 07:59 PM   #4
Circuit length may change the size conductors needed to compensate for voltage drop, but not ampacity.
Splicing of direct bury aluminum cable a7ecorsair Electrical 4 06-02-2010 12:50 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 09:10 AM
#6 aluminum cable penticton Electrical 26 03-11-2009 08:48 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
