2-2-4 SEU - Smaller Neutral? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 09:30 AM   #16
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
I too figured that is what you have.
To answer one of your original questions, yes it is permissible and common for the neutral to be sized smaller than the hots.
John
jrclen is offline   Reply With Quote
Old 09-23-2012, 09:09 PM   #17
Licensed electrician
Rewards Points: 1,266
Sounds like you have two services on the building, one East and one West. The services should be grouped.
Old 09-23-2012, 10:01 PM   #18
Sparky
Rewards Points: 510
Unless there is a main at the meter, in which everything at the house would technically be a 'sub' panel
Techy is offline   Reply With Quote
Old 09-23-2012, 10:25 PM   #19
And would need to be feed with SER, not SEU.
Need Neutral Connections - Installing Subpanel ctlu008 Electrical 10 01-01-2012 08:54 AM
3 way switch -OK to drop down neutral like this to light through switch box via 12/3? darlingm Electrical 9 12-22-2011 03:48 PM
installing new dedicated circuit - neutral bus full 7green Electrical 12 05-03-2011 02:32 PM
Electrical connections TazinCR Electrical 11 01-07-2009 08:10 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 02:23 AM
