2/2/2 AL Into 200A Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 02:55 PM   #1
Question
2/2/2 AL into 200A panel
OK, so here it goes. I am running a 100A sub-panel off of my 200A main panel. The Main panel is a Siemans and the sub is a homelite. My big question is how do I get the ground and neutral wires into the bars. They are too big to slide in and I don't feel comfortable with spreading the six wires across two positions. Is there a reducer that i should be using to make the install cleaner?? I am planning on having the work inspected and don't want to have a sloppy install job done. I am pretty comfortable working with electric, this is the first time I have worked with service wire and I am working in the dark. Thanks
njwoodworker is offline   Reply With Quote
Old 07-24-2011, 03:04 PM   #2
Licensed electrician
Rewards Points: 1,034
The conductor cannot be split like you suspected. Here is one kit.
http://www.drillspot.com/products/49...AN_Neutral_Lug
Another larger one is the LK100AN.
njwoodworker (07-24-2011)
Old 07-24-2011, 03:13 PM   #3
Master Electrician
Rewards Points: 3,684
Siemans parts: ECLK2 and ECCS 2.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Old 07-24-2011, 03:25 PM   #4
Master Electrician
I hope you are using 2-2-2-4 four conductor cable or three conductors in metalic conduit.
Old 07-24-2011, 03:57 PM   #5
it is 2/2/2/4 but I used Sch 80 PVC. It is only three feet from the main box. The whole point was to consolidate all of my garage and outdoor circuits in my sub-panel. It just seemed smart. If I need to change it to galvanized then I will.
Old 07-24-2011, 04:32 PM   #6
Master Electrician
No need to change the setup if you have the cable.
Old 07-24-2011, 05:37 PM   #7
Electrical Contractor
kbsparky's Avatar
Keep in mind that if you used #2 aluminum conductors, you can not use a 100 Amp breaker to feed your sub-panel. Table 310.16 of the Code allows 90 Amps on such a conductor, with 75 degree rating/terminations.
-KB
Old 07-24-2011, 06:05 PM   #8
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Did you run individual conductors or SER cable through the conduit?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-24-2011, 06:55 PM   #9
I used a 60 amp breaker with the thought that I could go up to 90 if it was ever necessary. Thanks
Old 07-24-2011, 07:15 PM   #10
electures's Avatar
You didn't answer my question. Just curious.
Old 07-25-2011, 01:39 AM   #11
Sorry, I used SER.
Old 07-25-2011, 02:00 AM   #12
electures's Avatar
Sorry, I used SER.
In this installation #2SER is rated for 75amps max.
Service move - old panel, separating neutral and ground WillK Electrical 3 06-17-2011 09:18 AM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 09:00 PM
More Sub Panel Questions rdkng07 Electrical 6 05-25-2011 09:46 AM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
Getting a new 200A breaker panel Any brand better than other? GE? Siemens? twilightcall Electrical 4 01-22-2008 08:57 PM
