1st Pulse Start Metal Halide Ballast... - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 01:06 PM   #1
1st Pulse Start Metal Halide Ballast... Edited...
Finally got a hold of a warm body at the Manufacturer...
They say cap off the second white wire on the ignitor... "it doesn't need to go anywhere", without pointing out the inherent danger.
A comment from another forum pointed out that...
"NO!! The starter is on the secondary side of the ballast. You NEVER hook secondary to primary. That's a great way to inject 2500 volts into your house wiring."
So I'm hooked up for 240V... going to remove and cap the extra white wire from the ignitor.
A little tenuous at this point though...
Any way to check out the set up before taking it live, Multi-Meter maybe?
Other thoughts before mounting, hanging, and energizing?
The Schematic with the kit looks like this:
The Ignitor for the kit actually has TWO white wires, so I've wired it like this; the second White going to Neutral on the Cords Plug:
The Modified Schematic for further clarity:
Am I doing this correctly?
Last edited by unhhuh; 02-10-2011 at 04:00 PM. Reason: Serious Injury And/Or Death...
unhhuh is offline   Reply With Quote
Old 02-11-2011, 12:20 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Before I can comment on this one can you run the ballast number and starter number and what wattage MH are you using ??
I look at the photo and it don't look quite right on this one.
Merci.
Marc
Old 02-11-2011, 12:42 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
You do realize that the 2 white wires coming out of the ignitor are connected together in the ignitor, right?
and the 2 wires labeled "ballast com" are connected together at the winding, right?
the "spare" wires are merely to facilitate ease of connecting the thing to various points that are not close to each other.
I'm missing what "inherent danger" there is by treating the second white wire from the ignitor as you were directed to do by the manufacturer is.
There is no effective difference between your two drawings.
Tags
ballast , metal halide , pulse start , schematic
Metal Stud Top Plate onto I Beam for NON Load Bearing Wall jdm001 Building & Construction 2 06-24-2010 10:31 AM
Mogul socket: 600V but can it support 120V? (Metal Halide Ballast) kithless Electrical 13 10-10-2009 12:19 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Metal halide lamp Richo Electrical 13 01-20-2008 02:37 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
