1955 Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 01:26 PM   #1
Rewards Points: 119
1955 electrical
We are looking at a house to buy. And are wondering if we'd have to rewire all the electrical.What are the chances of a 1955 home having a ground wire on the electrical. All the outlets are two prong. Want to know if there is even a remote chance before bring the Realtor back out to pull off some plug outlets.
Thank you
debd is offline   Reply With Quote
Old 12-30-2011, 01:29 PM   #2
DIY staff
Rewards Points: 7,174
More details---is the house piped in conduit?
Old 12-30-2011, 01:36 PM   #3
Rewards Points: 119
None are visable.
Old 12-30-2011, 01:36 PM   #4
MarginallyQualified
Rewards Points: 2,464
If it was convenient or practical to do so...
it's a safe bet that at sometime in the last 55 years someone would have.
Check anyway.
I recently bought a 1959 house with the old style no ground romex. My basement has full access to allow me to either change that wire (I won't)
or to add an extra receptacle (from a new grounded circuit) into each room for use by the rather few things that the ground will matter for.
When I remodel the kitchen and bathroom... those rooms will be fully rewired.
hth
Old 12-30-2011, 01:43 PM   #5
DIY staff
I'd factor in the cost of an electrical up grade when making an offer on the house---Has the incoming service been upgraded to breakers yet?
Old 12-30-2011, 01:48 PM   #6
Rewards Points: 119
no, and yes we are pricing what the upgrade would cost. the electrician said it'd be $1200 to $1800 to upgrade to an electrical box.
Old 12-30-2011, 01:51 PM   #7
Limited Experience
Remote? Yes. But I'd want very long odds to take the bet. Very long. Say 50,000:1.
But instead of pulling off outlet covers see if the homeowner will take the cover off the panel for the house and let you take a picture or two. But likely you'll have to hire an electrician to do this on a house you don't own.
raleighthings is offline   Reply With Quote
Old 12-30-2011, 01:55 PM   #8
DIY staff
How about interior rewiring? That is mostly labor--if you do the work yourself--$--
If you hire the work out--$$$--
Do you have the luxury of getting the house in shape before you would move in?
It's a lot faster and easier on the family if the messy stuff can be done without people and furniture in the place.
Most of us ordinary folks don't have that option---Mike---
Old 12-30-2011, 02:26 PM   #9
Rewards Points: 119
Yes, we'd do the work ourselves but thinking that it wouldn't be worth it... increase sellablity of house but not the value (this is an investment purchase)
Old 12-30-2011, 02:27 PM   #10
Rewards Points: 119
"take the cover off the panel for the house "
Good point, thank you.
Old 12-30-2011, 02:44 PM   #11
Rewards Points: 718
some insurance will not cover old houses if not rewired to be safe. If it is rewired totally you may have lower insurance rates also
carmusic is offline   Reply With Quote
Old 12-30-2011, 02:47 PM   #12
Limited Experience
If buying but with no plan to live there doing it yourself may not be an option
Old 12-30-2011, 03:20 PM   #13
Electrician
Rewards Points: 760
Why do you think you have to rewire the whole house because of ungrounded circuits, not a bad idea but not neccasary.
I have a house built in 1956 with ungrounded plugs and if someone came in and asked for a price reduction based on the electrical, that offer would quickly end up in the garbage.
If you are worried about it, all it would take is a few GFI and some new grounded plugs and a couple of hours of trying to figure out where the start of the circuit is. $100 or so for material another $100-$200 for labour. Is this worth fighting for on a house that is in the 6 figures.
darren is offline   Reply With Quote
Old 12-30-2011, 04:03 PM   #14
MarginallyQualified
Originally Posted by darren View Post
Why do you think you have to rewire the whole house because of ungrounded circuits...
They didn't seem inclined to consider this when I mentioned it either back around post 3 either.
OP: at the panel look for what sort of wiring is attached to it.
If you're lucky... it will be BX (armored flexible metal).
Old 12-30-2011, 04:45 PM   #15
biggles's Avatar
probably not they are using the BX run as a mechanical ground instead of a raw copper wire on the pull as and electrical ground...and you might even see cloth wiring within the BX.eye ball the pole feed into the house probably the same age....brin a meter along and test a plug if you pick up 115 to the plate screw the socket is grounded thru the BX..you pop the CB panel or screw in fuses you'll get an education
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Usefull Electrical Web Sites PaliBob Electrical 1 02-03-2009 11:49 AM
