1954 GE Stove: 3 Wire To 4 - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 01:31 PM   #1
Rewards Points: 12
1954 GE stove: 3 wire to 4
I just purchased a 1954 GE electric stove. It has a flourescent light and two 110,2-prong assessory outlets on top(just in case that needs to be known).
My home has the proper 4 wire outlet, but of course this old stove has only provisions for a 3 wire plug. I want to run by someone "in the know" what I have read online to be sure it's the proper way to update the stove to a 4 wire cord.
I've read that I should put the two hots (red and black) in their respective places on the stove's connection panel, the white neutral in the center.....and then I should disconnect the ground jumper-wire that runs from the stove's body to the neutral terminal and instead hook the green, ground wire on the plug directly to the stove's body.
It sounds logical to me....but I always edge on the side of caution, so I figured I would run this by you all to be sure. Thanks
semperfi1977m is offline   Reply With Quote
Old 08-01-2011, 01:39 PM   #2
I=E/R
a7ecorsair's Avatar
Wow a push button stove
Any chance you could post a picture of the wiring terminal block?
Does this stove have a bonding jumper?
a7ecorsair is offline   Reply With Quote
Old 08-01-2011, 04:59 PM   #3
Electrical Contractor
kbsparky's Avatar
You have it correct, semperfi. Post of pic of your work after you are done, before you replace the access panel.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
semperfi1977m (08-01-2011)
Old 08-01-2011, 05:25 PM   #4
Rewards Points: 12
thanks for the replies guys. Here's some pics of the terminal and the diagram on the back. Someone already had the ground strap unscrewed and bent back lol....its just below the neutral screw on the stove body (you can see it between the neutral and red wires of the cord in the pic I took)
Old 08-01-2011, 05:29 PM   #5
Rewards Points: 12
I have to still run into town later or tomorrow to get a new cord, but I will post pics when its in. Do you recommend that I find a new place to ground off of, or should connecting the green wire to the stove ground-strap suffice?
Old 08-01-2011, 07:11 PM   #6
kbsparky's Avatar
Remove that strap entirely, and attach the green wire to the frame where the strap used to be.
-KB
The Following 2 Users Say Thank You to kbsparky For This Useful Post:
Jim Port (01-20-2016), semperfi1977m (08-01-2011)
Old 08-01-2011, 09:23 PM   #7
Rewards Points: 12
Ok, sounds good! Thanks for your timeand your help kb
Old 08-03-2011, 10:51 PM   #8
Rewards Points: 12
She's wired and good to go!
Thanks for the help guys :-). Shes properly wired and ready for years more service. I opened the back and looked around...and the wiring is in remarkable shape on this old stove. The clock still works even!
Old 08-03-2011, 11:13 PM   #9
kbsparky's Avatar
Looks like your electrical connections are correct.
-KB
Old 08-04-2011, 12:11 AM   #10
Rewards Points: 12
yeah...it wasnt difficult, (was much easier than rewiring my whole truck last summer haha) I just wanted to be sure I had the idea correct on how it should be grounded. Thanks again :-). As you can see in the "before" pic, someone had the ground strap disconnected and the wires were on the outside of the terminal instead of sandwiched inside lol. Never ceases to amaze me the stuff people do.....the truck I rewired was because someone else's butcher-job caused all the wiring under the dash and the fuse panel to melt.....all from a butched radio install. Also the gas guage would go to "full" instead of the taillamps lighting up when you pulled the light switch on haha....because of a butched trailer-plug install.
Old 08-04-2011, 12:50 AM   #11
" Euro " electrician
frenchelectrican's Avatar
The only diffrernce between your stove and mine old stove I used have before is that the right front burner will have dual burner size plus it have thermosat to adjust the heat level { that was kinda pain in ase with it }
But for the left front it was large one as well that have dual burner size as well but no thermosat in there.
But good find with that stove.
Merci,
Marc
Old 01-19-2016, 04:54 PM   #12
Rewards Points: 16
Stove top elements 50's vintage GE range
Where do you find the stove elements for these on line ?
vjsimone is offline   Reply With Quote
Old 01-20-2016, 03:56 PM   #13
Oso954's Avatar
Rewards Points: 1,310
You can try
http://www.antiqueappliances.com/parts.htm
The old GE burners came in two styles. One had the trim attached to the burners, the other used a separate trim piece. You need to know which one you have to prevent ordering the wrong ones for your stove.
Oso954 is offline   Reply With Quote
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Extending Range Of Stove Electrical - bad idea? sleepysmurf Electrical 33 08-10-2010 09:30 AM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 10:44 AM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-14-2009 11:17 PM
New stove switch doesn't have place for earth wire warrickvdb Electrical 1 05-08-2008 12:18 PM
