1950s...Red Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2013, 06:13 PM   #1
Rewards Points: 14
Unhappy
1950s...Red Wire?
I have a double light switch at the top and bottom of my stairs...like 2 switches at the top and 2 at the bottom. Both control the same sets of lights in the basement.
So when I opened up the box to replace the old switches with some nice new ones I'm greeted with 3 wires on each.
With the black wires connecting to each other from switch to switch
Anyone have any idea what I should do? Are the red wires like old-school black ones or something?
I attempted to wire it up, and it "works" in that the switches in the basement turn the right lights on and off, but the switches at the top of the stairs do absolutely nothing, but blink the lights in the basement (if they're on)....like I'm just annoying the circuit
(See attached, the blue dots represent wires coming from the box, and the triangle is a cap to tie the wires together)
Thanks,
Steve
stevescotthome is offline   Reply With Quote
Old 11-23-2013, 06:35 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Red wires are regularly used. You have to find the incoming power and the switched black wire. Those go to the black screws. The other two wires go to the other two screws.
Old 11-23-2013, 07:42 PM   #3
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Thanks,
Steve
part of a 3 way switch set up
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 11-23-2013, 10:01 PM   #4
Rewards Points: 14
Really, thanks so much for the reply guys
I guess where I'm confused is why there's 3 to begin with?
White line comes from the panel, and travels out to black load which goes to the next device right?
...so...red is then???
How would I find the incoming power...?
Can you recommend a tutorial somewhere here? I'm good with dealing with the wires, but this is my first time having to replace a double-switch...it's like french to me. Well I guess it wouldn't be so bad if the switch I was replacing wasn't 50 years old with no notes on the switch.
Old 11-23-2013, 10:26 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,102
There are plenty of good tutorials on wiring a three way switch, just google it ! , pictures can make it easier to understand .
dmxtothemax is offline   Reply With Quote
Old 11-23-2013, 10:30 PM   #6
Rewards Points: 14
Thanks I can google that I just assumed "3 way switch" was like literally a switch that had 3 toggles or something, like up, down, middle
Guess that's pretty dumb though
Old 11-23-2013, 11:35 PM   #7
Rewards Points: 342
no it's not really dumb, i always wondered why they call them three ways when they only control lights in two locations. then the 4 way can be as many as you want as long as there between the 3 ways.
circuitman is offline   Reply With Quote
Old 11-24-2013, 12:22 AM   #8
Thanks,
Steve
The black wire on the bottom should go to the hot line in.
The reds and whites look like travelors to the other 3 way switchs,
So they should go to same terminals at switchs on the other end,
And the other terminal of each switch goes to the respective light.
The neutrals go to the fixtures of these lights.
Old 11-24-2013, 12:23 AM   #9
In Australia we call them "two way switchs",
because of the two different locations of the switchs.
The Following User Says Thank You to dmxtothemax For This Useful Post:
Philly Master (11-24-2013)
Old 11-24-2013, 10:18 PM   #10
Rewards Points: 342
i agree with ya! but on this side of the pond we call them 3 ways, why is any body's guess.wonder what ya would call 6 four ways in between?
Old 11-25-2013, 09:35 AM   #11
joed's Avatar
Rewards Points: 12,002
A normal switch has two ways, ON and OFF. So three way makes sense.
So does 2 way since you can use it from 2 locations.
Old 11-25-2013, 04:38 PM   #12
In Australia the middle switch, how ever many there may be
are called "intermeadiate switchs"
Old 11-25-2013, 11:09 PM   #13
Msradell's Avatar
Rewards Points: 126
Steve, did you write down or mark in some way how the wires were originally installed? Knowing that is certainly the easiest way to get things back working correctly. Without knowing that it's going to be somewhat difficult for someone here to help you. Pictures of what you presently have would certainly help.
Msradell is offline   Reply With Quote
replacing ceiling fixture - hole in ceiling with wire hanging out sunshine1221 Electrical 4 08-20-2012 10:53 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 05:24 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
