1925 House, Currently Carrying 30 Amps - Electrical - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 07:46 AM   #1
1925 House, currently carrying 30 amps
`How do I increase amperage from powerpole into house-breaker circuit 9or, junction box)?
thanks all!!
LITNING is offline   Reply With Quote
Old 11-22-2011, 07:50 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
thanks all!!
You might first give us a lot more info.
First suggestion is to hire an electrician. Based on your terminology you sound like you do not have much electrical knowledge or experience.
Coastal South Carolina
Old 11-22-2011, 08:00 AM   #3
Rewards Points: 6,652
thanks all!!
Along with installing a new drop, meter pan, breaker panel, the inside wiring would have to be brought up to date with the current codes. A load calculation would need to be done, to see if you need a 100 amp, 150 amp, or 200 amp service.
Old 11-22-2011, 08:00 AM   #4
Licensed electrician
Rewards Points: 1,884
You would need to get a permit, install larger wiring, upgrade any grounding or bonding, install a new panel, get an inspection and have the power company make the final connections.
I left out develop an accurate circuit directory and affix it to the panel. Install a new meter socket too.
Old 11-22-2011, 11:25 AM   #5
Rewards Points: 1,548
Part 1 -- Do the load calculation for the entire house.
Part 2 -- Install new service drop, meter, main panel (usually a separate permit and inspections from general wiring).
Part 3 -- Using a 10-2 cable, connect the old fuse block (disconnected from utility power as part of step 2) to a 30 amp breaker in the new panel. (Use 10-3 if it is a 240 volt @ 30 amp service.)
Parts 4a, 4b, 4c, etc. -- String new circuits to bring the house up to date code wise. You will probably be installing new kitchen and bathroom branch circuits first. You may be able to energize a few branch circuits at a time but it is possible that doing so may require separate permits for each group of circuits.
We suggest rewiring old receptacles onto new circuits or alternatively installing enough new receptacles to satisfy distance between receptacles without counting the existence of old receptacles.
Old 11-22-2011, 11:32 AM   #6
liscenced electrician
Rewards Points: 538
Also, if you have a fuse panel, replace it
jimmy21 is offline   Reply With Quote
Old 11-22-2011, 12:21 PM   #7
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
You likely have knob and tube wiring in there somewhere, which is oh-so-fun to deal with. That's what I'm replacing right now... and from what I'm told, inspectors are not a big fan.
mnp13 is offline   Reply With Quote
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Mast and weatherhead pulled from house, conflicting information from POCO subcontract SleepnZJ Electrical 1 11-02-2011 09:39 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
