18kw Electric Furnace - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 10:49 PM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
18kw electric furnace
Hi friends.
I've been trying to figure out how much monthly bills will be at a showhome i recently built this winter. From November 15 to December 10th, I had the heat at 50F set, and it used an unbelivable 143kw so far in that time period (18kw furance). My question is if i set the furance to say 65F or higher instead would it basically use the same amount of hydro anyways since its still always going to go on and off??
ryanh is offline   Reply With Quote
Old 12-12-2010, 08:27 AM   #2
Electrical Contractor
kbsparky's Avatar
143 kWh is unbelievably low for that kind of heat over 25 days.
Setting your thermostat higher will result in higher consumption of energy. Simple physics -- you will need more BTU's therefore it will make your electric bill higher.
-KB
Old 12-12-2010, 08:54 AM   #3
I=E/R
a7ecorsair's Avatar
Are you sure you have the correct numbers in you posting? 143KW means your 18KW furnace only ran 8 hours in a 25 day period. When you say an unbelievable 143KW is that unbelievably high or unbelievable low?
a7ecorsair is offline   Reply With Quote
Old 12-13-2010, 12:46 PM   #4
ryanh's Avatar
Rewards Points: 154
The Multiplier is 10. So its about 1800 kW.h/Month that the furance used set at 55 degree's. In a brand new R2000 insulated house.
Seems high to me, unless setting it at 72 or so won't end up actually being that much more.. I guess i'm lucky its only .65/kW.h
Old 12-13-2010, 06:28 PM   #5
kbsparky's Avatar
with a 10x multiplier, 1430 kWh sounds about right. Be prepared to use much more than that if you set the thermostat higher.
-KB
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Electric furnace huffhstn Appliances 0 12-08-2010 10:49 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
electric furnace need help Unregistered HVAC 3 10-16-2007 02:41 AM
