16 Gauge Wire To An 8 Gauge Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 04:02 PM   #1
16 gauge wire to an 8 gauge wire
If you have an extension cord with two 16 gauge twisted strand wires and you twist the ends together to make one wire, is it now equivalent to an 8 gauge wire?
jbvw is offline   Reply With Quote
Old 11-28-2010, 04:06 PM   #2
Mad Scientist
No.
McSteve is offline   Reply With Quote
Old 11-28-2010, 04:44 PM   #3
Rewards Points: 330
what ever you are trying to do ...DON'T....
oleguy74 is offline   Reply With Quote
The Following User Says Thank You to oleguy74 For This Useful Post:
Speedy Petey (11-28-2010)
Old 11-28-2010, 06:00 PM   #4
Rewards Points: 1,548
Two 16 gauge wires twisted together at both ends are roughly equivalent to one 12 gauge wire.
This may not be used for household wiring, either permanent or portable, but could be used for portable low voltage or loudspeaker wiring.
A 16 gauge wire emerging from a device such as a light fixture may be wire nutted to an 8 gauge feed wire but there is little usefulness* for this. The circuit feeding the light fixture or receptacle may not be breakered at more than 20 amps for which 12 gauge wires are sufficient.
* One use would be for a very long run, say hundreds of feet.
Old 11-28-2010, 09:00 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
I agree, what ever it is you are trying to do, STOP!
The fact that you are asking this is downright scary.
Old 11-28-2010, 10:21 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Whatever you do that part.,,, Ce n'est pas sūr { it is not safe }
Why you want to do soemthing with This ?? there is proper conductor sized items you can do in safe way.
Merci.
Marc
wire gauge on afco 20a breaker kevinp22 Electrical 13 09-23-2010 11:10 PM
Hot Water Heater Wire Gauge bphilip Electrical 16 09-18-2010 07:23 PM
20A Breaker, 14 gauge wire? joside Electrical 12 08-25-2010 09:41 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
Should a dryer be 10 gauge wire & range 8/3? twilightcall Electrical 7 07-03-2008 06:29 AM
