15amp Versus 20 Amp GFCI - Electrical - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 06:32 PM   #1
Rewards Points: 77
15amp versus 20 amp GFCI
I wired my whole house with 20 amp circuits. I was thinking of starting each receptacle circuit with a GFCI receptacle.
Will a 15amp GFCI be more likely to false trip than a 20amp?
bkvanbek is offline   Reply With Quote
Old 01-29-2012, 06:35 PM   #2
Licensed electrician
Rewards Points: 1,474
Both would trip at 4-6 mA.
Old 01-29-2012, 06:39 PM   #3
Rewards Points: 77
Would there be any other advantage to using a 20amp GFCI? I have yet to see a 20amp plug.
Old 01-29-2012, 06:40 PM   #4
Rewards Points: 13,446
Why would you do that? There only needed in the basement, garage, outside outlets and over the counter outlets.
The bedrooms need Arc fault breakers.
A GFI does not trip from to high an amperage draw.
Old 01-29-2012, 06:41 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Why would you want to feed every circuit in your house from a seperate gfi?
Theres already arcfault circuit breakers required in most areas of house (as certain people keep reminding me)
Then you have your tamper proof plugs that are required througout house.
Then you still need your tamper proof gfi's in the usual areas,not to mention your tamp proof weather resistant gfi's with in use covers required outside.
Other than wrapping yourself in bubble wrap and bonding yourself to the water service with a really long jumper wire just in case what else is there?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-29-2012, 06:41 PM   #6
joed's Avatar
Rewards Points: 12,362
Post your location in your profile.
If you are in Canada. It is required to use 20 amp T slot receptacles on 20 amp circuits.
Old 01-29-2012, 07:16 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Now THIS is funny!
The Following User Says Thank You to Speedy Petey For This Useful Post:
Code05 (01-29-2012)
Old 01-29-2012, 07:17 PM   #8
I agree with the others. WHY GFIs everywhere???
Old 01-29-2012, 07:21 PM   #9
Maybe to confuse the home inspectors?
Code05 (01-29-2012)
Old 01-29-2012, 07:31 PM   #10
Rewards Points: 77
I am in MN, the powers that be don't allow Canadians to post here do they?
A couple reasons, I have four outside receptacles on different circuits, and they need GFCI, so I might just as well put a GFCI on the first inside receptacle and protect them all. Right?
And my house might be a garage someday, my great room has two 10'x12' overhead doors.
And I think GFCIs work fairly well. But I am not a fan of Arc Fault.
Old 01-29-2012, 07:40 PM   #11
A fan of arc fault or not, they may be required by code in your area.
Old 01-29-2012, 08:35 PM   #12
Rewards Points: 77
Oh ya, arc fault are required.
But it is like I told a guy from the International Code Council. Codes should be optional.
Old 01-29-2012, 08:38 PM   #13
Once the code is adopted by the local areas they carry the force of law by my understanding. Not much optional there.
Old 01-29-2012, 08:44 PM   #14
Rewards Points: 77
I know, the ICC guy laughed when I told him, that codes should be optional.
Old 01-29-2012, 08:50 PM   #15
plummen's Avatar
The problem is many inspectors in smaller towns ive come across wouldnt know a code if you beat them over the head with the book!
And dont get me started on home inspectors!
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Can you test a non GFCI plug with a GFCI tester? DIYguy2000 Electrical 3 01-16-2012 06:49 AM
GFCI troubleshooting XwpisONOMA Electrical 20 11-13-2011 05:19 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
