15amp Outlet On 20amp Circuit?? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2010, 09:25 AM   #1
15amp outlet on 20amp circuit??
A while back, I had an electrician install a new 20amp circuit in my garage. I noticed last night that he used regular 15 amp duplex receptacles, instead of the ones with the 'T'-shaped prongs. Even the GFCI recep is 15-amp.
Since there are only 3 of them, should I replaced them, or leave them as is? I imagine if I try to pull 20 amps through one of them, they may burn up? Is this true?
Also, there is one switch on the circuit for a couple 4' fluorescent fixtures. Should I make sure this switch is rated at 20-amps also??? Even though it is only powering four 4' t-12 bulbs?
mopowers is offline   Reply With Quote
Old 02-02-2010, 09:35 AM   #2
Remodeling Contractor
not true. His method is correct. on 20 amp circuits using a 15 or 20 amp plug is by code and perfectly safe. 20 amp outlets are used primarily for commercial job.
Old 02-02-2010, 10:03 AM   #3
Yup, as stated 15a are rated 20a pass thru
A duplex receptacle is rated to be installed on a 20a circuit
A single 15a receptacle can't be installed
Old 02-02-2010, 10:53 AM   #4
So if I'm understanding correctly, the (2) 15a duplex receps, and (1) 15a GFCI recep are perfectly fine on the 20a 12g circuit. So I don't have to replace these. That makes me happy!
What about the 15a switch for the lights? Are these rated for 20a pass-through as well?
Old 02-02-2010, 11:36 AM   #5
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
This topic should be made a sticky, seems like it comes up every few days.
brons2 is offline   Reply With Quote
Old 02-02-2010, 11:38 AM   #6
yes.. code says "devices" which means receptacles and switches
Old 02-02-2010, 01:14 PM   #7
Just call me Andrew
Rewards Points: 1,020
As does the question of how many outlets can be put on one circuit.
Andrew
secutanudu is offline   Reply With Quote
Old 02-02-2010, 01:15 PM   #8
Rewards Points: 640
I hope you don't plan on having 20 amps worth of lighting j/k... you are fine... it's pretty standard pratice to have 15amp switches and recepticals (duplex ones) on a 20amp circuit... no single one will ever pull 20amps.. and if it does you probably have a different plug that wont fit into the 15amp outlet anyways
BlueBSH is offline   Reply With Quote
Old 02-02-2010, 01:16 PM   #9
Rewards Points: 640
Might as well answer that one too just to stop the next one
Old 02-02-2010, 01:17 PM   #10
Just call me Andrew
Good point
No limit in the US. I believe Canada has a limit.
Andrew
Old 02-02-2010, 01:19 PM   #11
Rewards Points: 640
Good point
we usually limit ourself to 8 devices on a 20 amp circuit just to be safe switches + outlets combined
Old 02-02-2010, 01:21 PM   #12
joed's Avatar
Rewards Points: 12,332
In Canada
Lighting must be on a 15 amp circuit. Not permitted on 20 amp circuits.
20 amp circuits require 20 amp T slot receptacles.
Limit if 12 outlets (lights, receptacles, fans etc.) per circuit unless known load (example - lights only) is connected.
Old 02-02-2010, 01:35 PM   #13
Just call me Andrew
Maybe a sticky with a FAQ is a good idea? It probably would have come in handy for a lot of people (myself included).
Andrew
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Replaced Outlet, but now tripping the circuit breaker bman598 Electrical 9 05-21-2009 07:35 PM
15AMP vs 20AMP for Office? mfleming Electrical 11 04-25-2008 08:50 AM
adding 20amp outlet for for welder Geophile Electrical 12 05-03-2007 08:17 PM
20amp circuit hammerhead Electrical 4 08-20-2005 08:10 PM
