-   -   15amp outlet on 20amp circuit?? (http://www.diychatroom.com/f18/15amp-outlet-20amp-circuit-63423/)
mopowers 02-02-2010 10:25 AM
A while back, I had an electrician install a new 20amp circuit in my garage. I noticed last night that he used regular 15 amp duplex receptacles, instead of the ones with the 'T'-shaped prongs. Even the GFCI recep is 15-amp.
Since there are only 3 of them, should I replaced them, or leave them as is? I imagine if I try to pull 20 amps through one of them, they may burn up? Is this true?
Also, there is one switch on the circuit for a couple 4' fluorescent fixtures. Should I make sure this switch is rated at 20-amps also??? Even though it is only powering four 4' t-12 bulbs?
Bob Mariani 02-02-2010 10:35 AM
not true. His method is correct. on 20 amp circuits using a 15 or 20 amp plug is by code and perfectly safe. 20 amp outlets are used primarily for commercial job.
Scuba_Dave 02-02-2010 11:03 AM
Yup, as stated 15a are rated 20a pass thru
A duplex receptacle is rated to be installed on a 20a circuit
A single 15a receptacle can't be installed
mopowers 02-02-2010 11:53 AM
So if I'm understanding correctly, the (2) 15a duplex receps, and (1) 15a GFCI recep are perfectly fine on the 20a 12g circuit. So I don't have to replace these. That makes me happy!
What about the 15a switch for the lights? Are these rated for 20a pass-through as well?
brons2 02-02-2010 12:36 PM
1 Attachment(s)
This topic should be made a sticky, seems like it comes up every few days.
Bob Mariani 02-02-2010 12:38 PM
yes.. code says "devices" which means receptacles and switches
secutanudu 02-02-2010 02:14 PM
As does the question of how many outlets can be put on one circuit.
BlueBSH 02-02-2010 02:15 PM
I hope you don't plan on having 20 amps worth of lighting :laughing: j/k... you are fine... it's pretty standard pratice to have 15amp switches and recepticals (duplex ones) on a 20amp circuit... no single one will ever pull 20amps.. and if it does you probably have a different plug that wont fit into the 15amp outlet anyways
BlueBSH 02-02-2010 02:16 PM
Might as well answer that one too just to stop the next one :laughing:
secutanudu 02-02-2010 02:17 PM
Good point :)
No limit in the US. I believe Canada has a limit.
BlueBSH 02-02-2010 02:19 PM
Originally Posted by secutanudu (Post 393442)
Good point :)
we usually limit ourself to 8 devices on a 20 amp circuit just to be safe :) switches + outlets combined
joed 02-02-2010 02:21 PM
In Canada
Lighting must be on a 15 amp circuit. Not permitted on 20 amp circuits.
20 amp circuits require 20 amp T slot receptacles.
Limit if 12 outlets (lights, receptacles, fans etc.) per circuit unless known load (example - lights only) is connected.
secutanudu 02-02-2010 02:35 PM
Maybe a sticky with a FAQ is a good idea? It probably would have come in handy for a lot of people (myself included).
