15AMP Microwave Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 08:05 AM   #1
Rewards Points: 101
I've got a microwave on a 15AMP (dedicated) circuit. The microwave's power requirements are 1500W. Is that 15AMP breaker enough?
michaelson is offline   Reply With Quote
Old 03-30-2012, 08:13 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Depending on where the circuit is, how old it is, and what the micro's instructions say, yes, it is enough.
Speedy Petey is online now   Reply With Quote
Old 03-30-2012, 08:21 AM   #3
Rewards Points: 101
The circuit is quite old, but it's working fine. I thought I remember something about it being a bad idea to load a breaker near its limits else it will overheat?
Old 03-30-2012, 09:04 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
The capacity of a 15 amp circuit is 1800 watts, at 1500 watts you are maxing out at about 83% (with the MW at full power setting). Since this is a dedicated circuit (your statement) and the MW is not a continuous duty device, you are fine.
The cicuit may not meet current code requirements but many older standards are grandfathered. If you were to do a major kitchen remodel you might be made to upgrade this circuit.
Coastal South Carolina
Old 03-30-2012, 09:05 AM   #5
Rewards Points: 101
What would be considered a continuous duty device? Lights?
Old 03-30-2012, 09:23 AM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Just a heads up...the manufacturer may spec a 20 A separate circuit. The manufacturer specs would trump the NEC if this was the case.
Old 03-30-2012, 09:33 AM   #7
Rewards Points: 264
michaelson,
Any load that will run for 3 hours or more is considered a continuous load. So unless you plan to microwave your turkey...
a_lost_shadow is offline   Reply With Quote
Old 03-30-2012, 10:59 AM   #8
joed's Avatar
Rewards Points: 12,904
You are fine. There are almost no situations that I can think of that might be considered continuous duty in a home. Baseboard heating maybe but it does not normally run for three hours continuous without shutting off.
Old 03-30-2012, 12:14 PM   #9
This is a bit misleading, which is very common regarding this topic.
A "continuous load" is a load that is EXPECTED to run for three hours or more.
For instance, commercial lighting is definitely considered a continuous load, but residential lighting typically not.
Some things, like an electric water heater, are specifically called for in the NEC to be considered continuous loads.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
a_lost_shadow (03-30-2012), HouseHelper (03-30-2012)
Old 03-30-2012, 02:37 PM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
You want to know what a continuous load is?
My wife on the computer looking at her Face Book page or playing scrabble with some of her internet friends......
Old 03-30-2012, 04:53 PM   #11
A "Handy Husband"
rjniles's Avatar
She (or you) is not getting enough sexor
Old 03-30-2012, 05:25 PM   #12
JOATMON
ddawg16's Avatar
No issues in that area....she just wakes me up when she comes to bed....
Microwave on own circuit? avmech Electrical 10 03-09-2011 09:02 PM
Rewiring older house WillK Electrical 12 10-13-2010 01:49 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
OTR Microwave installation bfarber Appliances 3 12-22-2008 07:55 PM
Microwave trips GFCI on a different circuit! Frank Kolwicz General DIY Discussions 7 06-01-2008 08:48 PM
