15amp Breakers, 14/2 Wire, How Many Recepticals? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2011, 07:35 PM   #1
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
15amp breakers, 14/2 wire, how many recepticals?
I have brand new 14/2 wire run through the walls.
I'm replacing all of the 15 amp breakers.
I have new 15A receptacles for all of the rooms. How many recepticales can I attach to each breaker?
One of the breakers runs 14 overhead lights, that can not be changed. I have four more breakers to share all of the outlets and 10 lights. I'd like to leave one of the breakers empty for the eventual bathroom remodel.
Yes, I can just divide them evenly, but what is the max safe load?
mnp13 is offline   Reply With Quote
Old 11-16-2011, 07:38 PM   #2
Licensed electrician
Rewards Points: 1,486
A receptacle itself adds no load to the circuit. The load is determined by what is plugged into the receptacles. There is no limit to the number of receptacles in a residence under the NEC.
A good design will plan for the expected loads.
Old 11-16-2011, 07:43 PM   #3
mnp13's Avatar
Rewards Points: 512
They are all bedrooms. I don't see more than lights, alarm clocks, and fans. Occasionally a vacuum or a power tool.
But I see your point... I'll just divide them up equally.
Old 11-16-2011, 08:09 PM   #4
liscenced electrician
Rewards Points: 538
circuits should be split up by rooms or sections of the house or whatever. Number of receptacles has nothing to do with it. (in residential applications)
jimmy21 is offline   Reply With Quote
Old 11-16-2011, 08:52 PM   #5
In a bedroom used just as a bedroom (for an adult as opposed to teenager), one 15 amp breaker would typically be fine for the whole room...
But you might have lots of things to plug in and more outlets would be a nice feature. And specifically on either side of the bed. Lamp, alarm clock, cell phone charger, whatever.... Yet there may only be one outlet BEHIND the center of the bed!
A better design might be to place a duplex outlet (4 total outlets) on the left side of the bed and another duplex outlet (4 total outlets) on the right side of the bed! Then plenty of outlets to plug all those things into.
Then when it is time to vacuum the bedroom, where is an outlet? They are all behind something! A better design might be to install an additional outlet near the door just for the vacuum.
Think ahead about these things and it can make life a little less frustrating!
As for the teenager's bedroom, let's see... 2 zillion watt stereo, microwave, TV, computer...
Billy_Bob is offline   Reply With Quote
Old 11-16-2011, 09:03 PM   #6
11 receptacles
longspur is offline   Reply With Quote
Old 11-16-2011, 09:05 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Originally Posted by longspur View Post
11 receptacles
How did you come up with this number?
Old 11-17-2011, 11:34 AM   #8
Not sure what your plans are for the bathroom remodel but you have to use 20 amp 12/2 for bathroom recepticles. Just something to keep in mind.
brucelee is offline   Reply With Quote
Old 11-17-2011, 02:13 PM   #9
Rewards Points: 6,652
Billy Bob, what kid has a microwave or large sound system in their room? Only place I can think of, would be a dorm room. Then it would be better to just wire every room as 20 amp circuits.
Old 11-17-2011, 03:45 PM   #10
mnp13's Avatar
Rewards Points: 512
Yup.
I have double 40's running the upstairs panel. That panel currently has five 15 amp breakers on it - three on one side, two on the other. I'd like to leave one blank, swap it out for a 20, and run the bathroom off of that. The bathroom fan will actually be powered from the downstairs (one fan for both bathrooms in the house, we shall leave that alone for now...), and the light can go on any of the other ones.
Old 11-17-2011, 03:47 PM   #11
mnp13's Avatar
Rewards Points: 512
We have already run about two dozen 14/2 wires. I'll end up divorced if I change my mind at this point!
14/2 NM wire problems tpagel Electrical 8 06-05-2011 09:58 AM
Wire Choice 12/2 or 14/2 Pentium Electrical 13 05-05-2011 03:33 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 04:24 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
