15amp And 20amp Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2009, 09:03 PM   #1
Rewards Points: 260
15amp and 20amp receptacles
Why can houses be wired with 15 amp receptacles on 20 amp circuits? Is it because it is assumed that a 20 amp device won't be used on a single outlet? Are 20 amp receptacles on used in a commercial setting?
bluefitness is offline   Reply With Quote
Old 07-18-2009, 09:17 PM   #2
dSilanskas's Avatar
Its more so about cost. The insides of a 15 amp and a 20 amp receptical are the same.
dSilanskas is offline   Reply With Quote
Old 07-18-2009, 09:42 PM   #3
The 15a has to be a duplex receptacle
A single 15a receptacle can't be installed on a 20a circuit (my understanding)
They are rated for 20a pass thru
Any device that needs 20a has a special slotted plug & requires a true 20a slotted receptacle. I have yet to buy any power tool that needs 20a or has a slotted plug
It doesn't have to be red or have the LED
Old 07-18-2009, 10:18 PM   #4
dSilanskas's Avatar
Yes you can install a 15 amp single receptacle on a 20 amp circuit
Old 07-18-2009, 10:25 PM   #5
NEC 210.21 (B) A single receptacle installed on an indivudal branch circuit shall have an ampere rating not less then that of the branch circuit
Single receptacle:
Old 07-18-2009, 10:29 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Don't forget, a duplex receptacle is two receptacles.
Is this correct regarding 20amp circuit and 15amp receptacles diymonkey Electrical 17 07-26-2009 07:57 PM
Can I use a 20amp outlet receptical on a 15amp circuit? abefroman Electrical 17 01-18-2009 10:57 PM
Question: Is using 12/2 wire, ok on 15amp breaker/outlets? ehoez Electrical 3 07-14-2008 08:41 AM
15AMP vs 20AMP for Office? mfleming Electrical 11 04-25-2008 09:50 AM
