15amp To 20amp - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2009, 06:43 PM   #1
Rewards Points: 115
15amp to 20amp
My air conditioner is on a line that has a 15amp circuit breaker. When it's 85 or above outside the air switches to fan then trips the breaker.
Now can the breaker be upped to a 20amp?
Thanks in advanced!
Carloscda is offline   Reply With Quote
Old 07-26-2009, 06:54 PM   #2
15a breaker usually only has 14g wire
In order to install a 20a breaker you need 12g wire
If it has 12g you can upgrade the breaker
If it does not have 12g then you would need to have new wire run
What is the AC rated for?
It should have a name plate
Is this a window AC? How big?
Anything else on the circuit?
Old 07-26-2009, 08:35 PM   #3
Rewards Points: 115
It's a 10000btu window air conditioner.
Along with my stereo equipment it's the only thing on that line.
Now could it be that the 15amp just needs to be replaced with a new 15amp breaker?
Old 07-26-2009, 09:25 PM   #4
Rewards Points: 1,016
Being that it is a 15a breaker, most likely it's 14 gauge wire from the breaker to the outlet for the air conditioner. For a 20a breaker, it must be 12 gauge wire.
Do not simply place a 20a breaker on a 14 gauge wire - this would allow more current to flow than the 14 gauge wire is rated for and would be unsafe.
Old 07-26-2009, 10:38 PM   #5
A 10,000 BTU AC could take 10a or more while running
And on initial startup it may draw even more then that
I have a newer 12,000 BTU on a 20a circuit w/other things/TV & had to run a new circuit
Is this correct regarding 20amp circuit and 15amp receptacles diymonkey Electrical 17 07-26-2009 06:57 PM
15amp and 20amp receptacles bluefitness Electrical 5 07-18-2009 09:29 PM
Can I use a 20amp outlet receptical on a 15amp circuit? abefroman Electrical 17 01-18-2009 09:57 PM
Question: Is using 12/2 wire, ok on 15amp breaker/outlets? ehoez Electrical 3 07-14-2008 07:41 AM
15AMP vs 20AMP for Office? mfleming Electrical 11 04-25-2008 08:50 AM
