Old 03-04-2009, 07:43 PM   #1
15a receptical on 20 amp circuit?
im changing my old black recepticals to white ones and i notice on my countertop outlets the recepticals (old ones) say 15a. but the breaker they are on is 20amp. is it ok that i change the old black 15a receptical to a white 15a on the same 20amp breaker?
fabian is offline   Reply With Quote
Old 03-04-2009, 07:51 PM   #2
Xtreme DIY'r
Yes, as long as it is a duplex - 2 places to plug a device in, VS only a single place to plug a device in
15a passes thru 20a
Old 03-04-2009, 08:27 PM   #3
Idiot Emeritus
The code reference here is Table 210.21(B)(3).
It plainly states that with a circuit (breaker) rating of 20 amps, the receptacle rating can be 15 or 20 amps.
The entire table applies only to circuits that have two or more receptacles. A duplex is two receptacles.
210.21(B)(1) prohibits the installation of a single receptacle on a circuit greater than the rating of the receptacle.
Rob
micromind is offline   Reply With Quote
Old 03-04-2009, 10:04 PM   #4
sweaty
The nice thing about using 20A receptacles is that it gives you a visual indicator of the higher capacity circuit.
sweaty is offline   Reply With Quote
Old 03-04-2009, 10:23 PM   #5
Electrical Contractor
And is a complete waste of money!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 03-05-2009, 12:03 PM   #6
sweaty
Why are they a complete waste of money?
Old 03-05-2009, 12:14 PM   #7
A 20 amp plug will not fit into a 15 amp receptacle.
(how many time has the average home owner even seen a 20 amp plug, maybe a AC unit)
When you have a need for a 20 amp appliance it should be on it's own circuit.
This way you only use 20 amp receptacles for dedicated circuits.
Use 15 amps for everything else
hpp58 is offline   Reply With Quote
Old 03-05-2009, 12:17 PM   #8
I agree with hpp. Most 20a appliances pull about 16 amps. There isn't much room after that.
rgsgww is offline   Reply With Quote
Old 03-05-2009, 12:21 PM   #9
thanks for the reply to my question. im always learning!
Old 03-05-2009, 12:32 PM   #10
Xtreme DIY'r
I buy Pro - heavy duty receptacles
The 20a were about the same price as the 15a
So I bought the 20a
Now under NEC 2008 all receptacles must be tamper proof
Outside must be GFCI & weather proof
Outlets have more then doubled in price
I'll probably swap the 20's out to the garage
That's the most likely place I will use them
Need a wiring diagram Mooreski Electrical 46 03-12-2011 04:25 PM
Can I use a 20amp outlet receptical on a 15amp circuit? abefroman Electrical 17 01-18-2009 10:57 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
