15a Receptacle On 20a Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2008, 12:33 PM   #1
15a receptacle on 20a circuit
Hi all,
I have two dedicated 20a circuits running to the kitchen. The first receptacle on each circuit is 20a gfci and I'm wondering if I can use 15a receptacles as the second outlet for each circuit. The reason I ask is I'm using cooper's aspire line and I can't seem to find 20a receptacles anywhere.
Thanks!
indignatz is offline   Reply With Quote
Old 01-07-2008, 02:14 PM   #2
no you can not
RYANINMICHIGAN is offline   Reply With Quote
Old 01-07-2008, 02:33 PM   #3
Originally Posted by RYANINMICHIGAN View Post
no you can not
Really? Is that because it's in the kitchen?
I thought all 15A receptacles were rated for 20A feed-thru, and a 15 amp outlet on a 20amp circuit was perfectly fine, as long as all the wire on the circuit is 20A.
NateHanson is offline   Reply With Quote
Old 01-07-2008, 02:38 PM   #4
Res Ipsa Loquitur
You CAN use 15a receptacles on a 20a circuit as long as it is along with other receptacles on the same circuit. You cannot use it if it is the only outlet on a 20a circuit, such as a dedicated outlet. In this situation you would need a 20a outlet. (This is the type with one horizontal and one vertical blade when looking with the ground facing down.)
By code kitchen have 20a counter circuits but have you ever seen a counter appliance with a 20a plug? No- because no standard countertop appliance (coffeepot, toaster, small microwave) draws 20a. If it did it would be dedicated- even a standard refrigerator doesn't use a 20a plug!
handyman78 is offline   Reply With Quote
Old 01-07-2008, 02:40 PM   #5
Rewards Points: 31
Has to be a two outlet pair also, a single socket would not be allowed.
Mdbuilder is offline   Reply With Quote
Old 01-07-2008, 05:44 PM   #6
Cool. Thanks guys. It is not the only outlet on the circuit (downstream from a 20a gfci outlet) so I will use the 15a receptacles for the second outlet.
Cheers.
Old 07-05-2011, 04:16 PM   #7
Rewards Points: 150
So am I correct in assuming I could add (8) 15A receptacles to a 20A circuit that is in the basement? Just looking for clarification.
stradt03 is offline   Reply With Quote
Old 07-05-2011, 04:21 PM   #8
Master Electrician
Rewards Points: 3,966
no you can not
That's news to many of the electricians across the country.
brric is online now   Reply With Quote
Old 07-05-2011, 04:22 PM   #9
Master Electrician
Yes you may unless local ordinances prohibit it.
Old 07-05-2011, 04:32 PM   #10
Rewards Points: 150
Excellent! thanks for the heads up.
Jason
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Adding a receptacle to existing circuit dekohl Electrical 3 09-10-2007 01:46 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
Double receptacle circuit TonyD Electrical 4 11-14-2006 07:00 AM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 09:28 AM
