15a Outlet Vs 20a Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2009, 03:05 PM   #1
15a outlet vs 20a outlet
What happens if I have a 20amp breaker, #12 wire and a 15amp outlet and the appliances plugged into the outlet drawings more than 15amps?
timchi29 is offline   Reply With Quote
Old 03-07-2009, 03:16 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
When the current gets significantly over 20 the breaker will trip.
Do not believe the old wives tale that the receptacle will burn up if it sees over 15A. A 15A receptacle IS rated for 20A feed-through.
Don't forget, a 15A duplex is TWO 15A receptacles, not one.
Speedy Petey is online now   Reply With Quote
Old 03-07-2009, 04:09 PM   #3
thanks. I just upgraded the wiring in the crawl space to # 12 and upgraded the breaker to 20amp and didn't know if I had to change out the outlet also.
Old 03-07-2009, 05:45 PM   #4
Rewards Points: 2,350
Also, if an appliance has a 15 A plug and it pulls more than 15 A, then it is malfunctioning.
Old 03-08-2009, 08:16 AM   #5
Electrician
Rewards Points: 792
If you happen to be in Canada, according to code that plug should be a t-slot plug. The chances of haveing a problem with the regular plug are very slim.
darren is offline   Reply With Quote
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
Adding garage outlet Shane Electrical 1 02-23-2006 04:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
