15A Extension Lead To 10A - Electrical - DIY Chatroom Home Improvement Forum
Old 06-21-2013, 11:41 PM   #1
15A Extension lead to 10A
Hi
I have a caravan with 2x15A outlets
I have 2x 15A extensions leads but only 10A power points at home.
I am wondering what I could do to fix this problem.
I thought of grinding the earth lead on the 15A extension lead to fit in a 10A socket.
Would this work and what would be the side effects of this.
sebjavierw is offline   Reply With Quote
Old 06-22-2013, 06:51 AM   #2
Electrical Enthusiast
Rewards Points: 504
Are you in Australia? Your terminology makes me think so.
What are these 15 amp plugs powering in the caravan? You could always change the plug to fit the regular 10 amp, but you risk blowing fuses/tripping safety breakers if you have a high power draw, which isn't a good thing.
The proper thing to do would be to have an electrician come and install the proper 15 amp power points.
Kyle_in_rure is offline   Reply With Quote
Old 06-22-2013, 08:18 AM   #3
Rewards Points: 13,472
Not sure how it works there but in the US any place that sells Caravans will have adaptor plugs with no wiring needed, just plug them in. As long as there both the same voltage.
Old 06-22-2013, 02:45 PM   #4
Rewards Points: 504
Let us know what you come up with.
Old 06-22-2013, 08:15 PM   #5
Yes I am located in Australia
I have found some adapters for 15A to 10A so I think I will go ahead and buy them rather than doing a dodgy modification
The Following User Says Thank You to sebjavierw For This Useful Post:
Kyle_in_rure (06-22-2013)
Tags
15a , electrical , lead
Resetting my toilet after tile install... MisterSteve Plumbing 24 01-11-2013 12:45 PM
Using an extension lead for a freezer in an outbuilding craig15 Electrical 5 11-27-2012 02:42 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Extending extension lead glunks Electrical 2 07-31-2010 08:32 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 01:23 PM
