Old 11-02-2009, 05:35 PM   #1
Default 15A circuit plans
I am upgrading some lighting and wondering if these plans are correct/code.
jrs034 is offline   Reply With Quote
Old 11-02-2009, 06:37 PM   #2
Not to code if you are in Canada. You are limited to 12 outlets in Canada. An outlet is a light or a receptacle.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-02-2009, 07:52 PM   #3
Extreme DIY Homeowner
Scuba_Dave's Avatar
Where are you located?
What kind of room is this?
What is the box at one end of the outlet run - breaker panel?
Is the junction box holding the switches?
You want all 9 lights turning on by 1 switch ?
I usually run 15a for lights & 20 a for outlets
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
Old 11-02-2009, 08:42 PM   #4
Located in Michigan
The box is the breaker panel
The boxes marked with "S" are the switches
1 switch for the lights
1 switch for one outlet
This would be for half of my basement
Old 11-02-2009, 08:47 PM   #5
Scuba_Dave's Avatar
I see nothing wrong
But I'd have 2 or 3 switches for the lights depending upon the layout
And I would put the outlets on a 2nd 20a circuit
You also want to eliminate that junction box or have the connections in the double gang switch box
The less junction boxes the better
Old 11-02-2009, 11:05 PM   #6
Outlets and lights on separate circuits is best - IMHO. And outlets on 20A.
Plug in something that pops the breaker, you still have lights.
Full power available for outlets.
Lighting circuit not heavily loaded.
Etc.
Old 11-02-2009, 11:29 PM   #7
Thumbs up Question if up to Code?
Also, a problem with "Box-fill" , in the Good Ol' US of A. According to NEC. The devil (can't capitalize that) is in the Details (No matter what) Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 11-02-2009, 11:35 PM   #8
Thanks for the help.....I should have said that this is an existing circuit and I want to redo from the J box out. I mixed the plan up a bit. The last outlet at the end on the left will not be there and minus 2 of the lights. I do want to control all the lights with the 1 switch.
Why is the J box bad idea....is it because of code?
No overload/code issues?
The lights are cans.....and its really for about a 3rd of the basement
Old 11-03-2009, 12:33 AM   #9
Child Alert! Pull Up!
fltdek's Avatar
If you separated the circuits, as mention in previous post, and which is typically the norm in electrical circuitry, this would eliminate the need for a juction box.
20A circuit for outlets
15A circuit for lighting
Junctioning wires has the potential for future problems to arise in that box, not necessarily saying it will, but is always a possibility, and if its covered (drywall) and you need to trouble shoot later on, now your looking for the box, openning up the wall to find the box...ect
fltdek is offline   Reply With Quote
Old 11-03-2009, 02:13 AM   #10
Junction boxes have to be left accessable.
Old 11-03-2009, 02:22 AM   #11
I can do it without the J box but I can't seperate the circuit...no room in the breakbox for another.
House was built 1969
Most of the circuits in the house have a mix of lights and outlets on them 15a and 20a.
I just want to change some of the lighting without having to redo the existing circuits or get a bigger breaker box. The changes in mind are small ( a few cans and florescents here and there). just want to make sure I'm not going over the 80%.
Most everything is not permantly covered(drop ceiling)....only some of the outlets are behind wall.
Old 11-03-2009, 10:08 AM   #12
You have no code issues with your plan as long as the junction box remains accessible. All of the suggestions are personal preferences.
If the basement is unfinished then you are required to use GFCI receptacles.
Old 11-03-2009, 01:42 PM   #13
Thanks for all the help/suggestions.
Old 11-03-2009, 01:53 PM   #14
Scuba_Dave's Avatar
You could possibly buy a tandem breaker - 2 breakers in the place of one
Depending upon your breaker panel
More On This Topic
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you Part 2 for drawing an electrical map. Next we are going to draw all of our outlets in our room onto our map. The symbol for an outlet is 2 lines coming out of the... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will show you Part 3 in mapping your electrical system. Now that we’ve mapped all of our electrical outlets, we are going to map our switches and our ceiling fixtures. So we are... Read More »
Amongst home do-it-yourself projects, electrical repairs are some of the most dangerous. On the surface, they can be deceptively simple, which makes it easy to forget that you're dealing with potentially fatal amounts of electrical current. If you don't... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip I will be talking about electrical safety. This particular sanding machine is 220 volts meaning it requires a lot more voltage than your typical outlet that you would have in your house... Read More »
Hi! I am Drew Finn, we are going to talk about how to clean and maintain your refrigerator for Expertvillage.com. We are going to make sure safe clean refrigerator, we have to get the power off to it, because we are sticking the brush, which is metal... Read More »
Need a wiring diagram Mooreski Electrical 42 10-04-2009 01:29 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 15 07-23-2009 04:40 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 09:59 PM
review my kitchen circuit plans DanBress Electrical 9 03-08-2008 08:07 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 10:09 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
