15A Breaker Overload? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-31-2012, 12:38 PM   #1
Trucon01's Avatar
Rewards Points: 510
15A breaker overload?
Hi All,
I have a single 15A breaker that splits to:
  • Bedroom 1 (Light and outlets)
  • Bedroom 2 (Light and outlets)
  • Full Bathroom (Light, outlet, fan)
  • 2 hallway lights.
It has never tripped since I've been here, but then again, one of the bedrooms is never used.
Should I try to get a dedicated 20A up to the bathroom?
Attached is my entire panel.
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 12-31-2012, 12:50 PM   #2
Rewards Points: 590
I would do it. That's a lot on 15A, and recent NEC code books demand a separate circuit for the bathroom for a reason. You must not have any female using hair dryers, or you would have flipped the breaker many times already.
operagost is offline   Reply With Quote
Old 12-31-2012, 01:04 PM   #3
Trucon01's Avatar
Rewards Points: 510
The hair dryer gets used on the Master Bed, Bath breaker. This one does trip on occasion... Maybe I'll try to run 2 separate 20A's up to that floor.
Any pointers when doing this? Is is normal to follow a vent pipe down to the basement?
Old 12-31-2012, 05:01 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Run a dedicated 20A circuit to both bathroom receptacles. Leave everything else alone.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following 3 Users Say Thank You to electures For This Useful Post:
brric (12-31-2012), micromind (12-31-2012), NJMarine (12-31-2012)
Old 01-01-2013, 02:17 PM   #5
Rewards Points: 528
Run one to the basement bath also- 20 amp, if you plan to install it later.(didnt see breaker for it)
hidden1 is offline   Reply With Quote
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 11:23 AM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 10:28 AM
AFCI Breaker Keeps Tripping Muinchja Electrical 30 08-25-2011 04:54 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
