1500 Watt Space Heater In Basemnet - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 12:06 PM   #1
1500 watt space heater in basemnet
I want to use a 1500 watt space heater in the basement, but I'm worrried about my electical circuit breakers handling it. I have a separate panel in the basement. I have sterero/TV hooked up and a fridge and bunch of lights. What do I need to look at on my panel to see if I should buy this heater?
it99 is offline   Reply With Quote
Old 09-29-2011, 12:14 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,970
Is the circuit it will be plugged into 15A or 20A? If it's 15A, there can't be much else on it at all. Maybe just a few lights. If it's 20A, you can have up to 7A (840W) of other stuff on it, though less would be better. Ideally you'd plug it into a different circuit from everything else but that's not usually an option.
mpoulton is offline   Reply With Quote
Old 09-29-2011, 12:15 PM   #3
Licensed electrician
Rewards Points: 1,758
You could install a receptacle on a new circuit just for this heater.
Old 10-21-2011, 08:08 AM   #4
question
The only thing my circuit breaker box has written on it is 10kw service and a 5kw service. I assume my basement has two circuits. Otherwise its just the schematic I'd have to read but that pretty small and its not light enough to read. I tried plugging in the heater to a power strip that had some lights also plugged in. Eventually it blew out the power strip, but not circuit breakers got tripped. I was going to replace the power stip. Is there a good kind to get that has a buit in circuit breaker? Or should I just try to plug in separetly from lights.
Old 10-21-2011, 08:17 AM   #5
I=E/R
a7ecorsair's Avatar
Do not plug a 1500 watt heater into a power strip. 95% chance it isn't rated for that much current.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
gregzoll (10-21-2011)
Old 10-21-2011, 08:55 AM   #6
question
I'm a little nervous about plugging in my heater directly into outlet and frying outlet. Should the 10kw and 5 kw on my panel be enough?
Old 10-21-2011, 09:03 AM   #7
Rewards Points: 6,652
Do not know the size of the basement, but a 1500 watt space heater is not going to do anything. We ran one in our basement, which is 821 only when my son would be down there playing video games, and it did nothing. Better to figure out how to warm it up by insulating the walls and pumping heat down there with the current hvac system.
Old 10-21-2011, 11:20 AM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 544
10KW and 5KW are meaningless numbers to us.
We need a picture of the panel.
Old 10-21-2011, 11:21 AM   #9
Me too with those numbers. I will take a picture of the panel tonight.
thanks!
Old 10-21-2011, 11:49 AM   #10
On the handles of the breakers in the panel, the single breakers will mostly all have 15 written on them or mostly all have 20 written on them.
That is the "amps" of outlet circuits and others. Ignore the "double" breakers.
So are they all mostly 15 or all mostly 20?
If you are lucky, there will be notes on the door for what breaker goes to what.
Billy_Bob is offline   Reply With Quote
Old 10-21-2011, 11:57 AM   #11
Depending on the age of the home, most likely it could be 15 amp circuits. Could also be Knob & tube or aluminum wiring.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
I would like to relocate the flue for my gas water heater Git HVAC 12 04-23-2008 09:37 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 10:28 AM
Space Heater And K-1 Kerosene bobo General DIY Discussions 7 10-25-2006 10:38 PM
