150 W ceramic bulb in shop lamp please help!
Yes.
You can put a heating element up to 600 watts in that socket.
Why 600?
An incandescent light bulb puts out 10% to 20% light and the rest of the watts consumed becomes heat. The worst case heat scenario is a 660 watt bulb (if one existed) with the 10% light output which means 90% heat which comes out to about 600 watts of heat.
The 250 volt rating means that it could be used safely on a 240 volt circuit which is the standard household circuit in many other countries.
For those who haven't seen them or antique parabolic radiant space heaters, yes they did make ceramic cylinder elements with Nichrome or similar heating wire coiled around, and with a screw in light bulb type contact base.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
