Old 10-13-2008, 10:48 AM   #1
Question
15 vs 20 amps
i was wondering if things like recessed lights or fart fans, which usually go on a 15 A circuit can go on a 20 A circuit ?
the thing is, the code requires that there is a 20A circuit going into the bathroom so i am trying to not have any other circuits other than that one.
thanks,
- a -
Old 10-13-2008, 10:51 AM   #2
joed's Avatar
15 vs 20 amps
Sure they can. You must use #12 wire for it all.
Old 10-13-2008, 10:56 AM   #3
Wink
15 vs 20 amps
but of course.
Old 10-13-2008, 11:25 AM   #4
Moderator
Termite's Avatar
15 vs 20 amps
Sure. Just remember that the 20amp circuit serving the bathroom cannot serve anything outside of that bathroom if that circuit includes the GFCI receptacle(s) serving the sink(s). If you've got your GFCI receptacles on a dedicated circuit, the 20amp additional circuit can serve the light, fart fan, and other rooms' lights/receptacles as well.
Need to wire in appliance 240 volts, 42 amps ekulrenlig Electrical 31 08-12-2011 11:45 PM
Generator as sole power source NGuy Electrical 29 12-20-2008 01:29 AM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 11:31 PM
Question about sharing nuetral (as in 12/3) wire Piedmont Electrical 19 01-22-2008 09:39 PM
Amps vs wattage moneymgmt Electrical 8 05-30-2007 08:13 PM
