15 Amp Outlets On 20 Amp Breakers? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-24-2010, 07:11 AM   #1
15 Amp Outlets on 20 Amp Breakers?
I'm replacing some old outlets. They are 15 amp outlets on a 20 amp circuit. Is this acceptable or should they be 20 amp outlets? I've been told that as long as there are multiple outlets on the same ciruit that they will be okay. The wiring is 12/2, which I know is correct for 20 amp service.
Thanks!
cjcpoker is offline   Reply With Quote
Old 12-24-2010, 07:40 AM   #2
Just call me Andrew
Rewards Points: 1,020
Where are you located?
In the USA, you heard right. As long as there are 2 or more outlets on the circuit (a standard duplex receptacle counts as two) you are fine.
Andrew
secutanudu is offline   Reply With Quote
Old 12-24-2010, 07:53 AM   #3
I'm not sure of the code requirements but it seems as though it would be dangerous to put a 15 amp outlet on a 20 amp breaker. If you happen to plug something in to the outlet that draws 18 amps the breaker won't trip but the outlet could burn up.
jerseyguy1996 is offline   Reply With Quote
Old 12-24-2010, 07:58 AM   #4
joed's Avatar
Rewards Points: 12,322
A device that draws 18 amps would have a 20 amp plug and would not plug into a 15 amp receptacle.
It's legal in USA but not in Canada. You need to post your location in your profile to get the proper answer.
Old 12-24-2010, 08:00 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 372
Any item that has an 18 amp draw, will have a 20 amp plug.
The biggest power hungry device that uses a 15 amp plug is a heater, and they are limited to 1500 watts=12.5 amps.
Old 12-24-2010, 08:02 AM   #6
Yes, I'm in the US. Thanks for the responses, I just wanted to be sure.
Old 12-24-2010, 08:28 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
This is completely untrue, and a myth perpetuated by folks who are not familiar with this stuff and the codes.
This is very similar thinking to that of a breaker tripping as soon as amperage is over a breaker's rating.
A 15A breaker will hold 20-25 amps for quite a while, yet the circuit is fine and everything remains normal, and the breaker will eventually trip.
A 15A receptacle IS rated for 20A feed-thru, even the cheap resi-grade devices.
Old 12-24-2010, 08:31 AM   #8
Well JB, we have all seen 1800 watt hair dryers, and they are perfectly legal to have a 15A plug, especially since they are not nearly considered a continuous load.
A circuit can have a load of 100% of it's rating.
This is another layman's myth, that a circuit can only be loaded to 80%. Not true.
Old 12-24-2010, 08:41 AM   #9
jbfan's Avatar
Rewards Points: 372
Yeah, forgot about the mega hair dryers!
I wasn't impling that the circuit was limited to the 12.5 amps that the heater would pull, just can't articulate as well as some of you guys.
Old 12-24-2010, 08:45 AM   #10
Oh I know. The second part was more for other folks.
Old 12-24-2010, 10:13 AM   #11
Master Electrician
Rewards Points: 3,808
Thanks for that, Speedy. I already knew it but far too many people, including experienced electricians don't get it correct.
brric is online now   Reply With Quote
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
GFCI breakers equivalent to GFCI outlets? Any code pitfalls? TomServo Electrical 27 02-04-2010 10:59 PM
GFCI outlets or breakers? gp_wa Electrical 25 11-07-2008 07:54 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
