15 Amp Gfi Wiring Question? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 08:24 PM   #1
15 amp gfi wiring question?
Can I use one these wiring diagrams to wire my powder room? It will be on a 15 amp circuit from the panel. It would be one light and a 15amp gfi.
jamestown55 is offline   Reply With Quote
Old 01-30-2014, 08:43 PM   #2
Rewards Points: 150
Bathrooms are required to be on a 20 amp dedicated gfi circuit. A gfi outlet will work too
romex1220 is offline   Reply With Quote
Old 01-30-2014, 09:07 PM   #3
I am in Ontario, Canada and understand I am able to run the 15 amp gfi under code here. Correct me if I am wrong?
Old 01-30-2014, 10:32 PM   #4
Msradell's Avatar
Rewards Points: 128
Either of your diagrams would work correctly if 15 amp GFI circuits meet the code requirements in Ontario. In the states we are also required to have a neutral wire in every switchbox under the new codes. In most cases this will be just capped off and that used but it's there for future automation needs. I'm also not sure if this is required by Canadian codes or not.
Msradell is offline   Reply With Quote
Old 01-30-2014, 10:33 PM   #5
joed's Avatar
Rewards Points: 12,016
Either one of those is fine in Ontario as long as they are 15 amp circuits. Receptacle must be GFCI. If you decide you want a 20 amp receptacle you need another circuit for the lights. Lights can only be on 15 amp circuits.
208V/3 Phase Wiring Question efalcon1 Electrical 12 09-28-2012 12:22 PM
Outdoor Wiring Question OKDrew63 Electrical 30 08-15-2012 12:25 AM
Adding 2 outlets in the middle of a series of outlets - wiring question Evan55 Electrical 7 06-14-2012 10:43 AM
Attic wiring question everyman Electrical 4 07-07-2009 10:47 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
