15 Amp Gfi Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 03:44 PM   #1
15 amp gfi question
Can I use a 15 amp gfi outlet in my bathroom? It will be hooked up with
14/2 wire. I understand it is not great for handling hair dryers etc. But it will
Be on our basement and this plug will never even get used. Not sure if that is
Against code in Ontario?
Thanks in advance.
jamestown55 is offline   Reply With Quote
Old 01-30-2014, 03:51 PM   #2
Rewards Points: 808
I don't know what Canadian code calls for, but US code now is dedicated 20a circuit to bathroom GFCI.
IslandGuy is offline   Reply With Quote
Old 01-30-2014, 04:16 PM   #3
Not sure if it makes a difference or not but it will be a powder room
No tub or shower. Just sink and toilet.
Old 01-30-2014, 07:42 PM   #4
joed's Avatar
Rewards Points: 11,998
15 amp GFCI is fine in the bathroom. Does not need to be a dedicated circuit like in the USA.
From ESASAFE site
Question
Is a separate circuit required to supply a receptacle in a bathroom?
Answer
The code does not require a separate circuit for bathroom receptacles. Bathroom receptacles can be supplied by a general purpose circuit that supplies other general purpose receptacle and lighting outlets. Multiple bath and washrooms are permitted to be supplied by the same circuit. Rule 8-304.
In bathrooms where heavy loads such as hair dryers may be used it is recommended not to combine multiple bathrooms on the same circuit.
Ontario Electrical Safety Code 25th Edition/2012
The Following User Says Thank You to joed For This Useful Post:
jamestown55 (01-30-2014)
Old 01-30-2014, 07:45 PM   #5
Thanks, can I run my light off that same circuit or will that be too much?
Old 01-30-2014, 07:48 PM   #6
Sorry, I only saw part of your post as I am on my phone...guess that answers my
Question.
Old 01-30-2014, 10:30 PM   #7
joed's Avatar
Circuits are limited to 12 outlets. As long as you stay below that you are fine. Outlets are defined as receptacles, lights, fans, or any other device that uses power.
Old 01-31-2014, 07:11 AM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
So weird... because we all know once we install 13 devices, that circuit trips... and it's not the fact that we have a heavy wattage appliance in use that should have a dedicated circuit....
The Following User Says Thank You to stickboy1375 For This Useful Post:
Kyle_in_rure (01-31-2014)
Old 01-31-2014, 12:13 PM   #9
Rewards Points: 808
I've never seen a hair dryer that would blow a 15a circuit on it's own, but know that they are sold up to 1500 watts, and that any signifigant load shared on your bathroom circuit will probably trip it. It's best to have a 20a circuit for that receptacle, or at least a dedicated 15a, separate from the lights.
Old 01-31-2014, 04:08 PM   #10
Rewards Points: 336
Originally Posted by jamestown55 View Post
it will be on our basement and this plug will never even get used.
If you're not going to use it, why install it at all? Is there a requirement for receptacles in powder rooms?
Keep in mind, when I bought a house a few years ago, it had a powder room with no receptacle. I though this was silly, so I had our electrician install one.
JKeefe is offline   Reply With Quote
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 02:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
