Old 11-28-2008, 04:19 PM   #1
15 amp gfci outlet on a 20 amp circuit?
I'm replacing the gfci outlets in my kitchen and I purchased 15 amp gfci outlets, but I just realized this is a 20 amp circuit. Is it OK to use these outlets, or do I need to have gfci outlets rated for 20 amps? Thanks.
Jeremy Hillary Boob, PhD is offline   Reply With Quote
Old 11-28-2008, 04:22 PM   #2
Electrical Contractor
It is ok to use the 15 amps gfci receptacles.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 11-28-2008, 05:58 PM   #3
Electrician
If you are in Canada you will have to get 20A GFI.
darren is offline   Reply With Quote
Old 11-28-2008, 08:05 PM   #4
The only time you need a 20 amp outlet (in the NEC) is when you have only one plug on the entire circuit. Do not get confused with a duplex receptacle, there are two plugs on those, hence the "duplex".
rgsgww is offline   Reply With Quote
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 11:18 AM
20A GFCI on 15A circuit jheavner Electrical 35 10-16-2008 04:45 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
GFCI and Smoke alarm circuit issues 00u6166 Electrical 9 10-30-2007 03:41 PM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 09:38 PM
