15 Amp Circuit Question - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2014, 05:38 PM   #1
15 amp circuit question
I'm rehabbing the dinning room of my cape (dining room is a former bedroom adjacent to the kitchen) changing the light source to recess cans on a new circuit.
When I removed the ceiling fixture I determined it ran from the panel toward another fixture in a convert bedroom closet with three more lines in a junction box,
So I found that on the circuit was lights for the cellar stairs, hallway going upstairs, outside the front door lights and pole light in front of the house.The Hallway has two way switches. So I tried to isolate each wire to figure out which one was which, and they showed no activity when connected to the known power source, hot wires coming from the room fixture. so I tried each one separately connected to the hot wires and got NO lights when switched on. So I put all the blacks together again along with the whites with the whites and connected them to the hot wires from the panel via the original light fixture junction and they had nothing, no lights when turned on.
The cellar stair wires which I didn't connect, now when tested with the meter are the hot wires. So the question is : and it took a while to get there... For the hall lights with a two way switch, would they be powered with hot wires in both directions (both ends have a feed)? How else would would the disconnected cellar lights have power unless it was coming from the other end of the full circuit. I connected all the wires back up with the room fixture and walls switch out of the loop and everything is back to normal.
If someone has an idea? Just a little mystified and needed to understand
Any help is appreciated.
Labman is offline   Reply With Quote
Old 04-05-2014, 05:48 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,460
Wow.... Kinda hard to keep up with your explanation and situation... at least for me.
Not sure, is there any way you could break that down a little more simply and clearly, or with a schematic/drawing..........
MTN REMODEL LLC is online now   Reply With Quote
Old 04-05-2014, 06:17 PM   #3
Basically, I had power run through wires that were disconnected from the original source in the circuit but in the same circuit, there is two way switches in the hallway. So for the power to arrive at the disconnect wires and make them hot, would there A.) Be a hot source in the loop? (2 way switches) or another explanation ?
Old 04-05-2014, 07:03 PM   #4
I am
I'm sorry...
would love to read the question but can't
seam like there's a bar of advertising on the right that cuts into the post on my iphone.
Not a problem but today it's doing it on my imac ... maybe it's the home depot advertisements on each side.???
UnclePhil is offline   Reply With Quote
Old 04-05-2014, 07:11 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
My guess is that there are alot of assumptions in your deductions that are probably not correct. If this is an old home, there is a possibility of switched neutrals and knob and tube wiring.
Old 04-05-2014, 07:14 PM   #6
I am
not sure what's going on...
two wires a hot and neutral (and a ground) go to all your receptacles to make them hot.
two wires a hot and neutral (and a ground) go to a light outlet to make it hot.
for a controlled on / off for a receptacle or light outlet a switch is wired in series in the hot wire feeding that receptacle or light outlet.
PS: advertisements are better
Old 04-05-2014, 07:17 PM   #7
I am
I take that back
Old 04-05-2014, 07:17 PM   #8
Does a two way switch- a light switch turns a light on or off at either end of a hall need a hot wire at each end?
Old 04-05-2014, 07:19 PM   #9
I am
no.....
Old 04-05-2014, 07:21 PM   #10
k_buz's Avatar
They are 3 ways, and no, they do not need a constant hot at both switches..
Many older homes were wired with switched neutrals. If you did your experiment in the case of switched neutrals, the light wouldn't work because it was seeing two hots with no neutral.
Old 04-05-2014, 07:23 PM   #11
I am
There are several ways to wire a three way switch "system"...??
depending on which box the power or switch leg come in or go out from..
Old 04-05-2014, 07:25 PM   #12
Nope built in 61
Just didn't understand why the wires to the cellar fixture when disconnected from the bunch was dead then when I connected all the wires up except the cellar wires, the bunch had no power and the cellar fixture wire became the hot lead? So wa the two ways reversing the direction of power flow along the circuit?
Old 04-05-2014, 07:26 PM   #13
I am
Not sure if this will help (as k-buz maybe on to what your looking at) but maybe one of these pictures in the link will help you understand.
http://www.google.com/search?q=3+way...=1798&bih=1063
Old 04-05-2014, 07:29 PM   #14
I am
Nope built in 61
?? maybe... tough to say ...you wired it
Old 04-05-2014, 07:29 PM   #15
k_buz's Avatar
What are you using to test for power?
They are 3 way switches, not 2 way.
The Following User Says Thank You to k_buz For This Useful Post:
UnclePhil (04-05-2014)
Homeline 200A 20 space/40 circuit load center question fdmillion Electrical 8 01-27-2013 03:20 PM
Circuit Breaker Troubleshooting Question - need help! DanLeonard Electrical 4 10-02-2012 12:20 AM
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 09:15 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Circuit Size Question techinstructor Electrical 12 06-28-2009 09:24 AM
