15 Amp Or 20 Amp? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2011, 07:54 AM   #1
Rewards Points: 111
15 amp or 20 amp?
Simple question.
I'm building a new PC with a 1250 watt power supply.
On the same line, a flat screen monitor, printer/scanner/fax (one machine), and a couple of small speakers.
Can I plug all of this into a standard 15 amp outlet, or do I need a 20 amp one?
Thanks.
wengang1 is offline   Reply With Quote
Old 01-14-2011, 08:01 AM   #2
Licensed electrician
Rewards Points: 1,634
The proper question to ask would be if a 15 amp circuit can supply all that equipment without tripping.
None of the cords will have a 20 amp end on it so a 15 amp conficuration is all you need. Circuit capacity is a different matter.
Old 01-14-2011, 08:36 AM   #3
Rewards Points: 6,652
You would have no problem with a 15amp circuit, since the Surge protector is only rate at 15 amps, it would trip regardless if on a 20 or 15 amp circuit, when it overloads.
