15 Or 20amp For Basement Finishing - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-30-2012, 12:18 AM   #31
" Euro " electrician
frenchelectrican's Avatar
The other thing I did not see in the plan is the luminaires.
How many are you plan to use and what type they are ??
I will give you a quick head up if you going to use the recessed cans luminaires size the circuit by the maxuim wattage it listed in the recessed cans the reason why I say that due some case you may put in 75 watt light bulb for a example but in fact you may use the CFL ( compact flourscent lamp ) which it will be 18 or 23 watts or use lower wattage indentscent bulbs.
And are you going to use them with dimmer as well ? if so please pay attetion to the wattage rating on the dimmer.
Most common dimmer wattage useally 600 watts rated but there are higher dimmer wattage rated like 1000 watts or 1500 watts.
But just be aware if you going to run multigang box with dimmer the derating may kick in depending on how many fins it have to be removed or numbers of gang in the box ( the dimmer installment instruction will mention that clear.)
Expect the dimmer to be warm when they are using ( my favour soluation is use the metal switch plate cover they act like big heat sink to keep it cooler )
Merci,
Marc
Old 11-30-2012, 07:05 AM   #32
Trucon01's Avatar
Rewards Points: 510
I'm using (6) 5in IC rated recessed lights on a 600w dimmer switch. I plan on using dimmable CFL bulbs (75w equiv), so my wattage shouldn't even be close, correct?
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 11-30-2012, 08:03 AM   #33
Rewards Points: 150
I think you have to size the circuit based on what you could use, not what you plan to use. If the recessed light fixtures are rated for 150W each, 6x150 = 900W, then you're over the rating of your 600W dimmer, even though you intend to only have ~150W of actual load using the CFLs..
Dave632 is offline   Reply With Quote
Old 11-30-2012, 09:40 AM   #34
Trucon01's Avatar
Rewards Points: 510
The housings are rated for 75w each. The CFL bulbs are 14 watts each but a 75 watt equiv. With CFL, you use the actual wattage of the bulb, not the equiv, correct?
14w x 6 = 84 watts
75w x 6 = 450 watts
Either way, I'm still under the 600w max on the dimmer.
This brings up a good question though...
I'll have a 15a circuit just for the main 6 lights in the room on a 600w dimmer. The dimmer will be in a 2 gang box with another 600w dimmer that will control 2 smaller recessed lights for a book shelf, all on the same 15a circuit. Is this ok?
Since the dimmers will be in the same box, sharing the same 15a circuit, will the wattage between them also be shared?
Old 11-30-2012, 09:44 AM   #35
TTW
TTW's Avatar
Originally Posted by redman88 View Post
run the 12/2 and just use 15amp breaker untill you need the 15amp
The wire size determines the breaker size.
14-2 you must use a 15 amp breaker
12-2 you have to use a 20 amp breaker
Think about it from a practical standpoint. Lights on, tv on, now out comes the vacuum cleaner and the breaker trips.
Makes no sense to run 20 amp wire and install a 15 amp circuit breaker, not to mention it is also against the NEC code.
Nope, I was wrong, just double checked, it is ok to put a 15 amp breaker on 12 wire. oops!
TTW is offline   Reply With Quote
Old 11-30-2012, 09:51 AM   #36
Trucon01's Avatar
Rewards Points: 510
Correct. I plan on doing 12-2 wire, 20a breaker with 20amp recepts. If I'm using the wire, Im not cheaping out on the recepts
He may have meant to use 15a recepts, not breaker...
Old 11-30-2012, 10:49 AM   #37
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
14w x 6 = 84 watts
75w x 6 = 450 watts
The lighing load is computed at the max the fixture uses.
1 15 amp circuit is fine.
When dimmers are mounted in the same box, they have to be derated.
Most 600 watt dimmers will be derated to 500 watts or less when mounted in the same box.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
frenchelectrican (11-30-2012)
finishing a basement? what, me worry? itsnotrequired Project Showcase 36 09-18-2012 06:00 PM
Downgrage 20amp to 15amp yonkoc Electrical 26 04-05-2012 08:56 PM
Question about 20amp outlet for my refrigerator Penguinfan Electrical 6 04-04-2012 07:36 AM
Normal level of finishing new drywall? MikeKy55 Drywall & Plaster 23 05-21-2011 03:42 PM
Finishing basment...light questions and more. Abs777 Electrical 10 02-19-2010 10:22 AM
