15 Or 20amp For Basement Finishing - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 08:52 PM   #16
JuzRick's Avatar
Originally Posted by k_buz View Post
2 15 A circuits
Tamper Resistant Receptacles
AFCI breakers
Smoke/CO Detector
As for the electric fireplace, its either going to be just fine on a 15 A circuit, or its going to have a heating element and require its own circuit. If you know where the fireplace is going to sit, run a dedicated 20A circuit to that spot. If you don't know where it is going to sit, run it when you get it.
K_Buz: I agree...
JuzRick is offline   Reply With Quote
Old 11-28-2012, 08:58 PM   #17
JuzRick's Avatar
Depending on the area he chooses to run the circuit for the fireplace, he needs to consider any possible tight spots, as in corners.. or areas that could cause complications when running that circuit when he's ready to proceed forward when you begins that phase.. as we're talking about all walls possibly being closed.
Old 11-28-2012, 11:01 PM   #18
Rewards Points: 43
Ever since tripping a 15A circuit breaker while using a vacuum cleaner on a circuit that already had some load on it, I will personally always use 20 amp circuits for receptacles. I think most vacuums, even modern day ones, draw 12 to 13 amps. This does not leave much room for other existing loads to be on the circuit before tripping a breaker. While breakers operate on time-current curves and as such will tolerate an overcurrent situation for a short period of time (depending on how much overload, etc), I look at the fact if you have a plasma TV (2 amps), a AV receiver of some type (1-2 amps), a dvr (~.3 amps), and maybe a lamp, or the AC adapter of a laptop computer adding an additional amp of power to the load and then connect someone decides to vacuum, you are going to be overloading a 15 amp circuit.
That is just my personal opinion...most people probably do not leave their TV on or have their computer open when vacuuming maybe :-).
dcapone is offline   Reply With Quote
Old 11-29-2012, 07:34 AM   #19
Trucon01's Avatar
Rewards Points: 510
And that is exactly what I was getting at before... I want to be able to have those things going and not trip a breaker, especially because this will eventually be a rental and I don't know how the hell this space will be used... There is a $25 increase between 14-2 and 12-2 and about $30 increase in 15a vs 20a recepts...
But I have experienced electricians on here saying to just use 2 15a circuits, someone else saying 2 20a circuits, etc
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 11-29-2012, 07:55 AM   #20
TTW
TTW's Avatar
Originally Posted by Trucon01 View Post
Here we go....
I'm not worried about the cost at this point. I want the best setup possible since everything is open. I want to do it right and have a tendency to over do things anyway. Eventually, I am going to keep this property as an investment house within the next 5 years or so, if that makes a difference.
Since everything is open now and it sounds like you don't want to have to do this again...
My personal opinion would be to run 2 20A circuits with 15 amp tamper proof receptacles.
Put them on afci breakers.
It's cheap insurance for future unknown usage. Might be overkill for now but...
How many square feet are we talking and will it be just one big room, or several? Will there be a bathroom?
TTW is offline   Reply With Quote
Old 11-29-2012, 08:12 AM   #21
Trucon01's Avatar
Rewards Points: 510
This is a prelim sketch I made up quickly. This is not to scale so the recepts are not as close as they appear
Feel free to give me feed back!
Old 11-29-2012, 08:14 AM   #22
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
20 amp receptacles are not required with a 20 amp circuit.
I run 20 amp circuits because when I started my area did not allow 14 gauge wire to be used, so it became a habit.
Old 11-29-2012, 08:26 AM   #23
Rewards Points: 43
A couple things and much more knowledgeable people can correct me if I am wrong (or you can depending how bad the scale is)...
1. You will most likely need a receptacle to the "left" of the bathroom door in the open area which I do not think would count as a hallway but rather part of the larger recreational room. It appears to be longer than 2 ft and as such, the wall space would require an outlet to be within 6 ft at all points.
2. Same for wall on left at bottom of stairs. Outlet for 1 could be positioned to satisfy the need of 6' to a receptacle for both sections of wall, but this depends on the actual sizes since the diagram is not to scale.
3. Same for the long wall of the utility closet. You may be able to shift the location of the outlet you have on the "stub" wall to satisfy the 6' rule here, again depending on actual size / scale.
4. As a general comment, depending on how your other bathrooms are already wired, it may be easier to wire the bathroom receptacles onto the same GFCI circuit as one of the other bathrooms and tie the bathroom lights onto the same circuit as the rest of the lighting. This can be done if one of the other bathroom circuits is ONLY serving receptacles in the bathroom and not any additional loads within the bathroom.
Old 11-29-2012, 09:47 AM   #24
Trucon01's Avatar
Rewards Points: 510
Right now, I'm working on the room with the 1 and 5 circuit. None of the other areas are even framed yet. That was all hypothetical. I'll def keep all that stuff in mind though. Thanks for such a detailed response!!
Old 11-29-2012, 10:11 AM   #25
TTW
TTW's Avatar
That looks fine to me. I agree with what dcapone said.
Old 11-29-2012, 11:06 AM   #26
Rewards Points: 528
Since it will be investment property down the road and others may be there later id stick w 12/2 .20 amp wire on both lines(1 seprate to fireplace) and 15 on outlets. many dont realize the overload till the multiple electronics/vac ,etc is poping the breaker(especially renters on a 15 amp)..
hidden1 is offline   Reply With Quote
Old 11-29-2012, 11:08 AM   #27
Rewards Points: 528
Since it will be investment property down the road and others may be there later id stick w 12/2 .20 amp wire on both lines w afci(1 seprate to fireplace) and 15 on outlets. many dont realize the overload till the multiple electronics/vac ,etc is tripping the breaker(especially renters on a 15 amp)..
Old 11-29-2012, 08:13 PM   #28
Engineer
Rewards Points: 161
Since I'm the "someone else" I'll pile on You can't go wrong with 20 amp circuits. The point of 15 or 20A circuits will always be argued (as you've seen) but if the small price increase isn't a dealbreaker, then there's really no debate; a 20A circuit is cheap insurance (as they say.) In your case I'd run 2 20A for the living space; of course the bathroom needs it's own circuit.
diystephen is offline   Reply With Quote
Old 11-29-2012, 08:26 PM   #29
Trucon01's Avatar
Rewards Points: 510
Debate over... 2 20amp circuits!
Thanks everyone!!!
The Following 2 Users Say Thank You to Trucon01 For This Useful Post:
jbfan (11-29-2012), TTW (11-29-2012)
Old 11-29-2012, 09:52 PM   #30
Rewards Points: 258
run the 12/2 and just use 15amp breaker untill you need the 15amp
redman88 is offline   Reply With Quote
finishing a basement? what, me worry? itsnotrequired Project Showcase 36 09-18-2012 06:00 PM
Downgrage 20amp to 15amp yonkoc Electrical 26 04-05-2012 08:56 PM
Question about 20amp outlet for my refrigerator Penguinfan Electrical 6 04-04-2012 07:36 AM
Normal level of finishing new drywall? MikeKy55 Drywall & Plaster 23 05-21-2011 03:42 PM
Finishing basment...light questions and more. Abs777 Electrical 10 02-19-2010 10:22 AM
