15 Or 20amp For Basement Finishing - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 08:13 PM   #1
Trucon01's Avatar
Rewards Points: 510
15 or 20amp for basement finishing
Hi All,
I'm to the point where I can start to run wire for my outlets. I've been doing some reading and what I see is that if you want to spend the extra money, install all 20 amp recepts on a 20 amp breaker. For 98% of the time, this will be over kill, I just don't want to run into an issue later if I want to put in a electric fireplace, etc.
Do you guys recommend spending a few extra bucks and do the whole basement in 20amp?
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 11-28-2012, 08:16 PM   #2
Licensed electrician
Rewards Points: 1,030
I doubt that you will find many items that need a 20 amp receptacle.
I would definitely install a 20 amp circuit.
Old 11-28-2012, 08:16 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by Trucon01 View Post
Hi All,
I wouldn't, but this debate is going to be a long one... Just do what you want/feel is adequate for you. Personally, you are much better off just running two 15 amp circuits than one 20 amp circuit....
Old 11-28-2012, 08:16 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Most electric fireplaces I have seen have required their own circuit, especially if they have a heater. I would much rather have 2 15A circuits than 1 20 A circuit.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (11-28-2012)
Old 11-28-2012, 08:18 PM   #5
Engineer
Rewards Points: 161
Most folks will not use 20 amp outlets, but my recommendation is to always use a 20 amp circuit (#12 wire) if you can swing it. Then use 15 amp receptacles (as they're cheaper) and receptacles are easy to switch out. When you run into a situation requiring a 20 amp receptacle, just switch out the receptacle in question. But if you're considering adding an electric fireplace I would wire a dedicated circuit for that (if you know where it might go.)
diystephen is offline   Reply With Quote
Old 11-28-2012, 08:20 PM   #6
E2 Electrician
What good is swapping out the receptacle when the circuit is most likely going to be overloaded at that point?
Old 11-28-2012, 08:24 PM   #7
Trucon01's Avatar
Rewards Points: 510
Thanks guys!!
I like the running 12-2 and using 15a recepts until I actually need a 20a idea... However, if running 2 separate 15a amps is the absolute best way, I may just do that.
Is one preferred over the other?
Old 11-28-2012, 08:27 PM   #8
Engineer
Rewards Points: 161
If that likelihood exists then the OP can do as you suggested and run multiple circuits at the start (especially a dedicated receptacle where an electric fireplace might be.)
Old 11-28-2012, 08:29 PM   #9
E2 Electrician
Thanks guys!!
You will never need a 20 amp receptacle, I've been in the trade a long time, and have only seen a handful of 20 amp appliances, and at that point, they all required a dedicated circuit.
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (11-28-2012)
Old 11-28-2012, 08:37 PM   #10
Trucon01's Avatar
Rewards Points: 510
Alrighty then...
So I'll just use 2 different circuits @ 15amps. Thanks for responding so quickly!
Old 11-28-2012, 08:41 PM   #11
Engineer
Rewards Points: 161
Thanks guys!!
Can you swing 2 20A circuits? One approach is to "leapfrog" outlets; where every other outlet is on the same circuit. That coupled with a dedicated circuit for a fireplace would help prevent future issues.
Old 11-28-2012, 08:45 PM   #12
Trucon01's Avatar
Rewards Points: 510
Here we go....
I'm not worried about the cost at this point. I want the best setup possible since everything is open. I want to do it right and have a tendency to over do things anyway. Eventually, I am going to keep this property as an investment house within the next 5 years or so, if that makes a difference.
Stickboy, you're up now!! yay or nah to this?
Old 11-28-2012, 09:01 PM   #13
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
What is the space going to used for?
Do you know where the fireplace will sit now, or have to wait until the space is finished?
As always local code will apply.
jbfan is online now   Reply With Quote
Old 11-28-2012, 09:04 PM   #14
Trucon01's Avatar
Rewards Points: 510
It will just be used as another family room type area. TV's, audio receiver, lamps, laptop, ipads, etc.
I don't know where the fireplace will be or if I will even put one in. It was just a possibility and wanted to cover all my bases.
Old 11-28-2012, 09:07 PM   #15
k_buz's Avatar
2 15 A circuits
Tamper Resistant Receptacles
AFCI breakers
Smoke/CO Detector
As for the electric fireplace, its either going to be just fine on a 15 A circuit, or its going to have a heating element and require its own circuit. If you know where the fireplace is going to sit, run a dedicated 20A circuit to that spot. If you don't know where it is going to sit, run it when you get it.
finishing a basement? what, me worry? itsnotrequired Project Showcase 36 09-18-2012 07:00 PM
Downgrage 20amp to 15amp yonkoc Electrical 26 04-05-2012 09:56 PM
Question about 20amp outlet for my refrigerator Penguinfan Electrical 6 04-04-2012 08:36 AM
Normal level of finishing new drywall? MikeKy55 Drywall & Plaster 23 05-21-2011 04:42 PM
Finishing basment...light questions and more. Abs777 Electrical 10 02-19-2010 11:22 AM
