14g Wire On 20 Amp Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 08:35 PM   #1
14g Wire on 20 amp circuit
I am installing motion light outside my garage this weekend. When I went to check the current wiring out in the garage, I noticed that the individual who I bought the house from had the garage door opener running from a receptacle w/14g wire...this is on a 20 amp circuit. I am about a year into my first house and slowly becoming a DIYer...but this just doesn't seem right. Is it safe to assume that I should change that 14g wire to 12g? The only pieces drawing power from this circuit currently are the garage door opener and a light.
dukes32 is offline   Reply With Quote
Old 12-01-2010, 08:41 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Yes it should be changed or breaker changed to 15.
Old 12-01-2010, 08:54 PM   #3
Rewards Points: 330
if the recp where the power comes from to lite and door opener is #12,cahnge the 14ga to #12 if you can.other wise you will need a 15 amp breaker on that ckt.
oleguy74 is offline   Reply With Quote
Old 12-02-2010, 07:47 PM   #4
Change breaker to 15A
Rob's Electric is offline   Reply With Quote
Want to change a single 240 volt circuit with only one outlet, to a 120 volt circuit with a standard 120 volt outlet. covenant Electrical 7 11-09-2010 06:07 PM
Burned wire coming from circuit breaker rdmirando Electrical 5 11-01-2010 05:32 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 10:44 AM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 05:00 PM
