Old 11-09-2008, 11:10 AM   #1
Question
147 volts?
i have been tripping breakers . after replacing 2- 20 amp breakers and a 100 amp main i found my power to have 147 volts. isnt this high for a standard apartment? what do i do?
gusco1 is offline   Reply With Quote
Old 11-09-2008, 11:18 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
147 volts?
Sounds like an open service neutral.
Do the lights in your house go bright and dim?
Does turning on the dryer or electric range have any impact?
I would call an electrician right away to rule out any problems inside your house.
Old 11-09-2008, 12:07 PM   #3
It was a dark and stormy
Yoyizit's Avatar
147 volts?
In MD it is supposed to stay between 126 and 114 volts.
Depending on how long the voltage has been doing this, some of your stuff will die prematurely, especially incandescent lamps.
Old 11-09-2008, 01:08 PM   #4
147 volts?
Sounds like a loose neutral as speedy petey stated.
Call an electrician asap, he will see if its any problems on your side of the service.
rgsgww is offline   Reply With Quote
Old 11-09-2008, 01:39 PM   #5
joed's Avatar
147 volts?
If this is an apartment as you stated call the landlord or an electrician. Do not attempt to service this yourself.
Old 11-09-2008, 04:11 PM   #6
147 volts?
Good catch Joe. I glanced right over the apartment part.
I agree. gusco, DO NOT do anything other than call your landlord.
Old 11-09-2008, 06:31 PM   #7
147 volts?
I would also unplug anything you don't need.
jerryh3 is offline   Reply With Quote
Old 11-10-2008, 05:55 AM   #8
DIY'er
jamiedolan's Avatar
147 volts?
I might also start unpluging anything you care about until this problem is resloved.
Jamie
jamiedolan is offline   Reply With Quote
Old 11-12-2008, 05:07 AM   #9
147 volts?
A very good "rule of thumb" applies here: voltage variation is plus or minus 10%. I would contact your utility first; has there been significant voltage variations? This sounds to me like a step-down transformer on your pole, or another location in the neighborhood. Current increases to the square of voltage drop-see Ohm's & Watt's laws.
DRFREON is offline   Reply With Quote
Old 11-12-2008, 06:54 AM   #10
147 volts?
Hey bcde871, SPAM much????
Old 11-12-2008, 06:55 AM   #11
147 volts?
Well, three days and no word from gusco.
He was on the site yesterday. You think he would have given us some more feedback.
Old 11-13-2008, 05:21 AM   #12
147 volts?
the voltage problem was the supply to the meter. dominion power fixed. everything is o.k. i thank you for the feed back. and not everyone is speedy,petey.
Old 11-13-2008, 06:51 AM   #13
147 volts?
Sorry if I offended you Gus.
It just gets very disheartening when someone posts a question, especially one that prompts more questions, and then disappears.
We all make an effort to help and get no feedback, even to clear things up.
Thank you for your feedback.
Old 11-13-2008, 10:40 AM   #14
UAW SKILLED TRADES
Stubbie's Avatar
147 volts?
Speedy you seem to get all the attention.......
Old 11-13-2008, 10:54 AM   #15
147 volts?
Agreed. Feedback from the OP is learning for us so we can better help the next person.
Looks like this OP posted and bailed.
Kind of like dine and dash, or gas and go.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Need to wire in appliance 240 volts, 42 amps ekulrenlig Electrical 31 08-12-2011 11:45 PM
240 Volts - 4 wire to 3 wire Richo Electrical 25 12-12-2008 09:50 AM
Neutral vs ground bullet Electrical 39 02-26-2008 01:18 PM
Does Home AC ever read 0 volts? step.gary Electrical 3 07-01-2006 04:57 PM
103 volts at switch? hawk1996 Electrical 1 06-01-2005 07:16 AM
