14 Gauge Wire 20 Amp Circuit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-24-2009, 02:44 PM   #16
Rewards Points: 278
Thanks everyone
did it all with the yellow 12 GA,
The jacket is as thin as the old 14 GA anyway.
Yes I used 15AMP receptacle for this add on.
I have gotten 20 AMP receptacle on my microwave and dishwasher circuits.
microwave being the only thing on the circuit, calls for a 20 AMP receptacle even the plug is 15AMP style
plus, it have great plug retention
DIYGST is offline   Reply With Quote
Old 06-24-2009, 04:39 PM   #17
Originally Posted by HouseHelper View Post
Yes, they are.
And just to be clear, while it is a violation to use 14ga wire on a 20A circuit in most cases, the 14ga wire will not burst into flames or all the insulation melt off if the current goes to 20A.
No, but the temp. rise above ambient will be (20/15)^2 times what it would be if the wire carried 15A.
I guess the insulation will just get brittle faster.
Old 06-24-2009, 07:32 PM   #18
Licensed Pro
Not really. Remember, the listed ampacity for 14ga THHN (which is really what NM-B is) is 25A. It's the NEC that mandates, for most applications, the OCPD be limited to 15A.
Old 06-24-2009, 08:47 PM   #19
OK, so the temp rise at 25A is ~(25/15)^2 = 2.8x what the rise would be at 15A. I hope it's less than 90C, for a 30C ambient.
http://www.tcforensic.com.au/docs/article10.html
Old 03-05-2013, 12:00 PM   #20
15 amp change to 20
I have a office with multiple appliances it 12 gauge wire throughout with a 15 amp breaker I want to change the breaker to 20 amp do you see any problem with this?
scaponio is offline   Reply With Quote
Old 03-05-2013, 12:06 PM   #21
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Originally Posted by adpanko View Post
Yep, 20A breaker needs 12 gauge wire as per code.
But here is a theoretical question that makes sense in my mind. Let's say you have a few outlets on a 20A breaker and all are wired with 12 gauge wire. Assume you want to add a doorbell, and you tap power off of the last outlet in that 20A circuit. So you have to run wire from that last outlet to the 12 or 16 volt doorbell transformer. So beyond the outlet, the only possible draw of power will be the dinky little doorbell. So why wouldn't a gauge smaller than 12 be allowed between that last outlet and the doorbell transformer since it doesn't seem possible that anything beyond that last outlet will be drawing a lot of amps? I would think it would be okay to just use 14 guage between the outlet and the doorbell transformer. But I assume the answer is no. Just curious if anyone has any insight. Thanks.
If you tap off that 12 and use 14 then someone uses that feed to instead supply a heater and not a doorbell or ties into it to supply something else. Then you could have someone drawing more power than the wire is rated for. Just easier to keep the same gauge wire on the whole circuit.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-05-2013, 12:40 PM   #22
Rewards Points: 512
Is there anything wrong with #14 to #12 tails on a a 20amp circuit?
Old 03-05-2013, 12:48 PM   #23
Rewards Points: 349
This really should be a new thread. This one is from 2009.
al_smelter is offline   Reply With Quote
The Following 2 Users Say Thank You to al_smelter For This Useful Post:
sirsparksalot (03-05-2013), Speedy Petey (03-05-2013)
Old 03-05-2013, 12:51 PM   #24
jbfan's Avatar
Rewards Points: 648
As long as you are sure it is all 12 gauge and copper wire.
I agree with Al, this thread is from 2009.
Old 03-05-2013, 04:15 PM   #25
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Yes, it's a code violation.
The Following User Says Thank You to stickboy1375 For This Useful Post:
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
Where to wire in to circuit brackh Electrical 5 02-28-2008 06:04 AM
Gauge Wire and Breaker Discrepancy broken_scout Electrical 26 12-22-2007 10:07 PM
12 gauge wire to 14 gauge on an outlet question diyer4162 Electrical 35 12-20-2007 12:55 PM
HELP with Arc Fault Circuit Interruptors! samf Electrical 3 11-24-2006 10:56 AM
