14 Ga Wire Okay? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 06:16 PM   #1
Rewards Points: 77
14 ga wire okay?
I was planning on wiring my garage with 20 amp circuits for the receptacles and 15amp for lights.
For the workshop area I will have 4 six 32 watt lights (768 watts) and two ceiling fans at 76 watts (152 watts) for a total of 920 watts, the home run to the switch for these would require about 80' and then 60' more for the lights and 30' for lights. Can I still do this in 14ga/ 15amp?
bkvanbek is offline   Reply With Quote
Old 04-22-2013, 06:28 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You are allowed 1800 watts on a 15amp circuit....
Old 04-22-2013, 06:30 PM   #3
Rewards Points: 77
Originally Posted by stickboy1375 View Post
You are allowed 1800 watts on a 15a circuit....
But is that that run length too long?
Old 04-22-2013, 06:31 PM   #4
E2 Electrician
I wouldn't worry about it...
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 02:41 AM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
