14 - 6" HALO Cans Too Much? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-27-2013, 04:42 PM   #1
Rewards Points: 117
14 - 6" HALO cans too much?
I am hanging recessed lights throughout the basement.
I plan on having theses 14 cans on 3 zones with dimmers. Is this too much?
Ceilings are 7.5 ft.
Here a pic I made of the layout.
tommyxv is offline   Reply With Quote
Old 07-27-2013, 04:52 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
For sure...no doubt...without question.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (07-28-2013)
Old 07-27-2013, 05:03 PM   #3
Rewards Points: 117
I kind of thought so... can you recommend a layout for this room size?
Old 07-27-2013, 05:12 PM   #4
k_buz's Avatar
Take out the middle row of cans.
Move the two remaining rows off the walls 4'.
Put the two lights in front of the TV on their own switch/dimmer.
Old 07-27-2013, 05:23 PM   #5
Rewards Points: 117
Sounds like a plan! Thanks for the guidance.
Old 07-28-2013, 10:53 AM   #6
Rewards Points: 348
Put them ALL on a dimmer/s.
herdfan is offline   Reply With Quote
Old 07-28-2013, 12:21 PM   #7
Electrical Contractor
kbsparky's Avatar
Put LED trims in all of `em ....
-KB
Old 07-28-2013, 03:51 PM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
6" cans are so 80's by the way, go with 5" cans and you can still install the same wattage lamp, but eliminate the meteor look alike in the ceiling.
Old 07-28-2013, 08:08 PM   #9
Bill Kearney
Rewards Points: 1,174
FOURTEEN OF THEM? What're you trying to set up, a warming station like for sandwiches at an Arby's? That's way too much lighting. Especially with ceilings that low. What leads you to think you want THAT MUCH lighting?
That and you'll have to check whether your circuits AND the dimmers would even support that many lights.
wkearney99 is offline   Reply With Quote
Old 07-28-2013, 09:17 PM   #10
" Euro " electrician
frenchelectrican's Avatar
Take the centre row out that is too much for this purpose.
By the way becarefull with circuit sizing on this one we always size it by max wattage of the luminaire not the actual bulb at all. You may end up have two circuits for sure no question asked if you use common 5 or 6 inch non IC cans but max wattage will depending on the trim useage.
Most case I know useally either 75 or 120 or 150 ( watts ) depending on the set up of the can et trims.
Keep the two cans on it own dimmer front of the TV centre ( you may end up use deep baffled verison to keep the glare down ) But for the rest the BR30 useally work pretty well in most case.
Merci,
Marc
Old 07-29-2013, 08:08 PM   #11
dmxtothemax's Avatar
Rewards Points: 5,600
What type of lamps are you thinking of using ?
Incandesant ? Halogen ? CFL ? LED ?
If there all incandesant or halogen then it's gunna get awefull hot !
Then your A/ C works double time tryng to dissapate the heat load !
How many lights you use depends on the beam width of the luminare
and your required light levels ?
What will be the main uses of the space ?
dmxtothemax is offline   Reply With Quote
Old 07-30-2013, 12:09 AM   #12
Rewards Points: 117
Thanks for all the replies. I ended up taking out the middle row and spacing the other two rows 3.5 ft off the walls front and back walls and 25" from the sides. I'll be wiring them up in 3 zones tomorrow. We'll see how it goes.
I was planning to do that.
I was going with HALO one piece LED/trim/baffles.
I bought the 6" ones already. They were on sale. H7ICT model.
LOL
I am using a dedicated 20A circuit for the lighting in the TV and Poker/Game room. Would be 5 lights max on a dimmer. Using all 12/3 (for 3 ways), and 12/2 wired.
Merci,
Marc
These are IC cans. I took into account that each fixture is rated for 75 watts max. I was going to stay under 1920 total watts (80% load) on this dedicated 20A lighting circuit based on the possibility of a 75w bulb in each can.
The space is a TV/Family room. Using LEDs for sure. 3500k in the office and 2700k every where else.
http://www.homedepot.com/p/Halo-6-in...9#.UfdI743VCBI
Old 07-30-2013, 05:16 PM   #13
A tv / family room does not need high levels of light !
So I would go for a lot less lights.
Leds would be good !
6" Halo remodel construction recessed housing bulb safety question yrralrellim Electrical 5 04-02-2013 03:34 PM
New IC rated recessed cans camner Electrical 8 05-21-2012 11:07 PM
Commercial Electric vs. Halo recessed lights bubbler Electrical 0 10-12-2011 07:06 PM
Halo recessed lighting willyboy Electrical 0 09-01-2010 07:34 AM
