14-3 On A20A Circuit??? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-01-2009, 11:26 AM   #1
14-3 on a20A circuit???
I've got a piece of 14-3 that I could use to connect two 3-way switches that operate a stairway light. The rest of the circuit is 20A with 12-2. Is it OK to use a piece of 14-3 to connect my 3-ways and still have the circuit be on a 20A breaker??
Thanks!
red86yota is offline   Reply With Quote
Old 03-01-2009, 11:28 AM   #2
No, you need 12 on a 20A circuit.
Plumbvoltage is online now   Reply With Quote
Old 03-01-2009, 12:08 PM   #3
You would need to install a 15a breaker
Not a good idea when there is #12 at the breaker panel & someone could later install a 20a breaker not knowing you installed a lower gauge wire.
Old 03-01-2009, 12:42 PM   #4
OK thanks...I thought it might fly if the 14-3 was only connecting the 3-ways that have a minimal load...just trying to use some leftover 14-3. Guess I'll pick up some 12-3 for my connection
thanks!
Old 03-01-2009, 04:08 PM   #5
Rewards Points: 2,350
You know, in Gilmer County, Georgia the Code allows for #14 switch legs on 20 A circuits. That is the only instance of #14 allowed in a residence there.
But in your case, either use #12 or change the breaker. Not ideal, but it really doesn't matter what someone might do in the future. They might put a 50 A in there later, they might tie it straight to the main lugs, etc.
Old 03-01-2009, 06:44 PM   #6
Electrician
Why would they do that? I'm not worried that they do, but just find it strange that they allow it. What if the load was more that 15 amps? (I'm still not worried if it is more than 15amps either )
chris75 is offline   Reply With Quote
Old 03-01-2009, 08:47 PM   #7
Don't know... I guess they figured if it were, you would know it and install the appropriate switch and wire? My boss loved it cause he could save $40. Made no sense to me.
Old 03-01-2009, 09:58 PM   #8
GC/Master Plumber/Mech
Rewards Points: 560
It's that way in KS as well
Think the reason is that it is a light fixture and not a 20a recp.
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 04:09 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
