14.3 To 14.2 Adding Two Outlets...now Everything Is Hot - Electrical - DIY Chatroom Home Improvement Forum
Old 09-06-2014, 08:14 AM   #1
14.3 to 14.2 adding two outlets...now everything is hot
I need help bad... I split a 14.3 line already running to a switch( I think) put in a junction box. I want to add two outlets going in different directions from the junction box and am using 14.2 out of the junction box. I connected all 4 black, all 4 whites, all 4 grounds, and the two reds....The outlets are hot. Unfortunately the lights before the junction box have a low flow and are lighted. There is a switch for the lights, and i believe a second switch that operates the lights however it is not working.(maybe a bad switch). Should I have put one of the reds to one of the outlets? and black to the other? Or should I cap the red? OMG...I am so lost here.. Anyone have any words of wisdom?
Jenni88 is offline   Reply With Quote
Old 09-06-2014, 08:37 AM   #2
Rewards Points: 1,578
yep. Call in an electrician. Unless that was a multi-branch circuit, you can't do it.
Was the original switch a 3-way (one of two switches controlling a light)?
bob22 is offline   Reply With Quote
Old 09-06-2014, 08:41 AM   #3
Recommendations for LED lighting brands
deleted
Old 09-06-2014, 08:51 AM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Jenni
It sounds like you located your junction box between two 3 way switches that control the lights. This will not work.
You need a constant power source with a neutral and you have your junction box and outlets connected to a switched power source in that 14/3 cable.
How hard would it be to connect to the constant power feeding the 3 way switch circuit ?
Are there any other receptacles close by that you could get contant power from?
If you could post some pictures of the two 3 way switches with the box covers removed and the switches pulled out with the wires still attached we might be able to help you. Or let us know if there is a receptacle close to the area your working.
Remember to always have the circuit breaker off to what your working on. You need to know how to use a voltage tester. Your skill level suggests it would be best if you have someone knowledgeable help you with your project.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 09-06-2014, 08:58 AM   #5
Yes, but I didn't know it at the time...Have just figured out that the switch that didn't control anything was part of it...
Old 09-06-2014, 09:04 AM   #6
OK...so can I disconnect everything and put it back the way it was and the lights will work correctly? Then find another source for the outlets?
Old 09-06-2014, 09:06 AM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Yes you can. But the junction box will be required to be accessible
You said that one of the switches didn't do anything? did you mean it was the one you referenced earlier that stopped working after you put in the junction box ?
Stubbie
Old 09-06-2014, 09:18 AM   #8
no...it didn't stop working after I connected the junction box....it has never worked...or we never figured out what it was for, so maybe the switch has been bad all along. I will put a new switch in and see if that is the problem....after I reconnect the splice in the junction box...then I will find another source to run the outlets off....Thank you for all your help...and yes, I disconnected the breakers and know how to use a multimeter to check for power...don't like shocks, death, or the house burning down...
Old 09-06-2014, 02:28 PM   #9
Ok so now I want to run the two outlets off another outlet....how should I do that?
Adding 2 outlets in the middle of a series of outlets - wiring question Evan55 Electrical 7 06-14-2012 09:43 AM
Changed Outlets...Lights stay on... agentphish Electrical 4 03-29-2012 09:02 AM
Need to rewire outlets and lights..HELP suboveryde Electrical 1 11-02-2010 06:19 PM
adding new outside outlets, lights etc walt1122 Electrical 8 08-23-2007 02:11 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
