14/2 Vs. 12/2 Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2010, 08:02 PM   #1
14/2 vs. 12/2 questions
Hey gang,
I know that you have to run 12/2 wiring for 20A circuits, but the question if have is whether you need it for everything on that circuit. I have a bathroom and am literally 1' short on 12/2 wiring to go from a switch to the exhaust fan. The fan will not draw 20A (obviously), so I would think that I could just as well use some 14/2 as I have plenty of that left over from my basement project here.
Is that OK per code? I would think so, but figured I would ask you guys.
sanny651 is offline   Reply With Quote
Old 03-06-2010, 08:07 PM   #2
NO, 14/2 can't be installed on a 20a circuit
The Following User Says Thank You to Scuba_Dave For This Useful Post:
sanny651 (03-06-2010)
Old 03-06-2010, 08:15 PM   #3
OK. I'll have to go buy some more 12/2 then. Out of curiosity, why would that be? I understand that the 12/2 is to handle the extra amperage, but on that one branch the amperage draw would be what....an amp maybe? Is it that way so as to eliminate any confusion or something....kind of an "all or nothing" gig just so you know what you're dealing with?
By the way Scuba, I really appreciate your help. You've given me lots of advice, either directly or indirectly via reading your other posts. Much appreciated man!
Old 03-06-2010, 08:35 PM   #4
I can't cite the specific reason...other then 14g is only rated for 15a and 20a circuits must use 12g
But- I think...you may only install something that draws a lot less then 15a
Then the next person installs something that takes more
Or they extend the circuit...and based on the 14g wire they use 14g
Ideally anyone else should see that 14g wire & only install devices based on that
It just doesn't meet code
Thanks.....Yeah...I'm a stay at home Dad & working on the house
Winter can be very boring for me
I'm hoping that changes this year as the major house work is done
Old 03-06-2010, 08:35 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
so, what would happen if you tied more onto that branch of the circuit. Maybe even put on enough that would over load a #14 wire?
HHHmmmm???
While safety wise right now there would be no problem, who is to say what happens in the future?
So, you just limit a 20 amp circuit to a #12 wire. Just makes it easier and better over all.
besides that, code says that is how it needs to be.
Old 03-06-2010, 08:46 PM   #6
Good point about the extension of the circuit down the road.
Mind you, I wasn't trying to get around things or anything, but rather just trying to understand the logic as to why. You just proved why...didn't think about the extension aspect.
I'm not one to just do because I'm told to do...I want to know the "why" behind the direction to do something.
Thanks for the input fellas!
Old 03-06-2010, 08:55 PM   #7
Yeah...you can't prevent every future modification
But the code tries to prevent as much as it can
Old 03-06-2010, 10:52 PM   #8
Journeyman Wireman
Rewards Points: 150
As a residential service electrician, whenever I encounter #14 wire on a 20a breaker, I immediately downsize the breaker as required by the NEC. Often I don't have any idea (or even care) how the rest of the circuit is wired or what loads it might serve.
Jupe Blue is offline   Reply With Quote
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
12/2 wire vs "heater wire" shtoink Electrical 11 11-23-2008 02:16 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
Moving from 12/2 to 14/2 bbarnhart Electrical 4 12-04-2005 06:26 PM
