Is 14/2 Ok For Fridge ? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-29-2012, 01:59 PM   #16
Licensed electrician
Rewards Points: 1,266
Newer refrigerators are now using less energy than the older appliances. I doubt that whoever wrote about the 20 amp plugs at the big box appliance section has ever taken a look or found a 20 amp cord cap.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Speedy Petey (09-29-2012), stickboy1375 (09-30-2012)
Old 09-29-2012, 02:03 PM   #17
Electrician
Rewards Points: 778
Who cares if it has place for 500 pizza the cord end is still a normal 15A plug so 20A is a waste.
I have never seen a home appliance with a 20A cord end on it, I have only seen a few in the commercial work i do on a daily basis.
darren is offline   Reply With Quote
The Following 3 Users Say Thank You to darren For This Useful Post:
Jim Port (09-30-2012), Speedy Petey (09-29-2012), stickboy1375 (09-30-2012)
Old 09-29-2012, 09:24 PM   #18
Bombastic Idiot
notmrjohn's Avatar
I've seen, found, and used 20 amp cord caps. I've purchased them at big boxes and electrical supply houses, even Habitat for Humanity Restores, . I've seen them on new domestic microwaves and reefers. I've even seen electricians install 20A outlets on walls in kitchens I've remodeled. There is no need for you to get up on your high horse.
Yes, newer appliances appliances use less energy than older ones. A small "dorm sized" one only draws 4 amps, I should be able to run that one on bell wire and an in line fuse.
A quick Google will find lots of microwaves that require a 20 amp circuit, mostly built ins that are hardwired. Many more recommend it. A quick Google will find many reefers that recommend, if not require a 20A circuit. A quick ramble thru this or other DIY forums , DIY and electrical advice sites, many hosted by licensed electricians such as yourself , also shows lots of 20A recommendations.
Here's a guy, Degree in Electrical Construction & Maintenance (Dean's List), Master electrician,OSHA Safety Certified (10 & 30) runs two electrical companies “...with a short run of 12/2 ...Connecting the microwave this way....(to a new receptacle mounted to an old work box) - it will be tied into a 120 volt 20 amp circuit....and be properly protected.”
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/Undercabinet-Oven-Microwave-wiring.htm
These guys say 12 on 20 is required, I never said that, http://electrical.about.com/od/wirin...ngcircuits.htm
Here's from my reefer manual, “A 115 volt, 60 Hz., AC only, 15- or 20-amp fused, grounded
electrical supply is required.”
https://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10407369.pdf
page 6
A microwave manual “A 120 volt, 60 Hz, AC only, 15- or 20-amp electrical supply
with a fuse or circuit breaker”
http://www.whirlpool.com/digitalassets/GH7208XRS/Installation%20Instruction_EN.pdf
page 3
I have never seen a home appliance with a 20A cord end on it” As I said, I have. I can't say what you see in commercial applications but 20A is not rare on commercial stand alone reefers and freezers here and take a look at 1200 watt and larger commercial micro waves.
A waste? 3 or 4 cent difference in price per foot between 14/2 and 12/2 NM-B. If you read my posts, you'd see that I agree that 15A is fine and no problem. You'll also see why I think 20A is better.
I can still build a house with 2x4 studs and meet code most places, but 2x6 despite the few dollars more is better. For one thing, and this is not me saying this but a structural engineer, “... when the electrician and plumber get through drilling their holes, at least some of the stud is left with the 2X6 stud."
http://www.eng-tips.com/viewthread.cfm?qid=316468
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-29-2012, 09:45 PM   #19
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,876
Yeah you guys. Get down off your high horses!
Old 09-29-2012, 09:59 PM   #20
Electrician
Rewards Points: 778
Sorry I saw Jim up there and wanted to go up as well.
The Following User Says Thank You to darren For This Useful Post:
Speedy Petey (09-30-2012)
Old 09-29-2012, 10:22 PM   #21
You are right Petey, I was getting a nose bleed up there.
Old 09-29-2012, 11:25 PM   #22
Bombastic Idiot
notmrjohn's Avatar
Glad you're amused, if you've seen my posts you know i like to bring a bit of lightheartedness to the subject, as well as advice based on knowledge I've gained over last 50 years or so. I'll also throw in some opinions and disagree with other opinions. I've never talked down to anyone or called anyone a liar, which is what jim came very close to doing.
I have no beef with darren, merely a disagreement over whether up grading to 20 amp is a waste or improvement. He might convince me, but we'll probably never agree on that.
I'm sure Mr Port is very knowledgeable and proficient at his trade. If he wants to argue with manufacturers, other electricians, or even poor ignorant me, stumbling around the huge scary big box, not even knowing what I am looking for, he probably has points worth listening to. But ad hominem arguments rarely convince any one of anything.
Old 09-30-2012, 02:55 AM   #23
Code05's Avatar
Rewards Points: 1,104
Originally Posted by HARRY304E View Post
All the receptacles in a kitchen must be on 20 amp circuits except the refrigerator which can be on a 15 amp circuit with no other loads.
No, not all receptacles in a kitchen, regardless of the 15A or greater fridge circuit, are required to be on a 20A circuit-only SABCs.
Dishwasher, disposer, compactor, range hood, etc could also be on 15A circuits.
Code05 is offline   Reply With Quote
Old 09-30-2012, 05:16 AM   #24
Rewards Points: 150
Usually, the dishwasher, disposal, etc. are hard wired, aren't they?
Dave632 is offline   Reply With Quote
Old 09-30-2012, 05:40 AM   #25
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
dishwasher - commonly hardwired but can be plug and corded to meet the requirement for a disconnect.
Disposer - more often plug and cord but can be hardwired.
Coastal South Carolina
Old 09-30-2012, 07:51 AM   #26
I am not trying to insinuate that anyone is lying. I do however have a healthy doubt of much that is written and does not seem to have much basis like the part about the big box information. Even the built-in Sub Zero in one kitchen I worked on had a 15 amp cord end.
I would consider the 20 amp circuit an improvement if the homeowner was getting a benefit from it. I looked at my refrigerator and it shows less than 7 amps. This is less than half of even the 15 amp circuit so not even the smaller circuit is close to being maxed out.
Old 09-30-2012, 04:06 PM   #27
Bombastic Idiot
notmrjohn's Avatar
Jim, I owe you an apology, here it is. I misread your post and jumped to conclusion, not 1st time for me. "...whoever wrote about the 20 amp plugs at the big box appliance section..." I see now you were addressing big box writer not me. If you wanta remount, I'll even give you a leg up. ( This is 2nd time I'm typing this, 'puter crashed just as i hit "Post" and who knows where, 1st attempt wound up. So you know i mean apology.)
None the less, more and more opinions and advice, some from more "authoritative" sites than these anonymous forums, is for 20A dedicated circuits for large appliances, especially hardwired ones and many manufacturers of combo range hood/ microwaves require it.
20A is overkill, but if price and other things are considered it may be "better," just as over building a wall may be. A "better" than 15A on 14 would be 15/12. No need to re-plug appliance or replace outlets. I've been using NM 12-3 for my new or re-wiring 'cause I get a great deal on partial rolls at Hab for Humanity Restore, less than 14 at big box.
Code05, ya got me confused, another common state for me. "...not all receptacles in a kitchen... are required to be on a 20A circuit-only SABCs." So SA's need to be on 20A? But larger ones can be on 15? Or am I misreading something again? Misinterpreting what is meant by SABC? When does appliance stop being small and become power hungry behemoth ?
In re-reading to see where thread got off track from Fixin's original query, I saw this,"i have enough 14/3... i will run the fridge off 1 wire, then the rest of the "whatever" off the other wire." I'm assuming he won't run both hots off same breaker, but wouldn't that require a separate or at least larger neutral?
Fixin, " owners emanual.... doesn't even say the power consumption" There may be a seperate installation manual, go to manufacturer's site and see if they have online manuals. There also may be a spec section for your model. ( Bet it says to connect to 15 or 20 amp circuit.)
OK were it goes, gonna push button. Wish me luck, good or bad, depending if you are on Percheron or Shetland pony.
The Following User Says Thank You to notmrjohn For This Useful Post:
DangerMouse (10-01-2012)
Old 09-30-2012, 10:45 PM   #28
No problem.
Old 10-01-2012, 09:14 AM   #29
Rewards Points: 222
this is the fridge i have. i still don't see where it states power consumption.
http://www.lg.com/us/refrigerators/l...r-refrigerator
but at any rate, with the newer models being more energy efficient, i believe i am ok with what i did. as the new wire is better quality. and the old wire has been running at higher volumes for decades.
Fix'n it is offline   Reply With Quote
Old 10-01-2012, 10:23 AM   #30
Rewards Points: 150
Fix'n's right. I followed every link I could on the LG site, and nothing about current consumption. Owner's manual, spec sheet, tech specifications page... the closest it came was saying 115VAC @ 60Hz, which wasn't exactly a surprise.
About the only place I could think to look would be on the back panel of the fridge itself for some kind of builder's plate.
By the way, fix'n, how did you fit the fork lift into your kitchen to position that monster?
20 amp circuit using 14/2 wire? Overloaded beachfront71 Electrical 13 01-02-2016 01:11 PM
Mixing 14/2 and 12/2 wire on one circuit? dekohl Electrical 12 03-13-2012 08:19 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Wire Choice 12/2 or 14/2 Pentium Electrical 13 05-05-2011 04:33 PM
Wire a 4-way light circuit with 14/2 HooKooDooKu Electrical 22 01-28-2010 03:31 PM
