Old 06-04-2011, 09:40 PM   #1
14/2 NM wire problems
Wiring a sub panel today. My first. The 12/2 NM was easy. Had the ripping tool to slice the yellow sheath and had no problems. But that tool mangled the 14/2 wire. I guess each wire in it is encased in the grey vinyl? How are you supposed to get the wires free? Do you have to slice each one individually with an exacto knife? I think I ruined a whole homerun because of this problem. Tips?
tpagel is offline   Reply With Quote
Old 06-04-2011, 09:49 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Grey vinyl? I can only assume this is UF cable and not NM-B.
UF can be very difficult to strip. Carefully slice ONLY the grey sheathing and pull back each conductor.
Speedy Petey is online now   Reply With Quote
Old 06-04-2011, 09:54 PM   #3
Oh. Is there a yellow vinyl kind? I asked the clerk at the big box store for 14/2 wire, and the grey stuff is what he gave me. He give me the wrong kind for an interior renovation? My remodel is still bare studs and no gyp bd, and I only have one lighting circuit, so I suppose I could rip it out and use something else if need be.
Old 06-04-2011, 09:57 PM   #4
I=E/R
a7ecorsair's Avatar
UF (Underground Feed) rated cable is very hard to work with especially if it is your first time. If you don't need UF, all your wiring is inside, go get a roll of 14-2 NM. How did you end up with 14-2 UF?
a7ecorsair is offline   Reply With Quote
Old 06-04-2011, 10:00 PM   #5
Just checked the wire. Yup. They gave me UF. My bad, though, for not knowing what I needed beforehand, I guess. Arghhhhhhh.
Old 06-04-2011, 10:56 PM   #6
Missouri Bound's Avatar
Ask for romex next time....if there is a next time. As far as the UF goes, yes it definately is a pain in the a** to strip.
Old 06-05-2011, 01:12 AM   #7
Semi-Pro Electro-Geek
14-2 NM cable is white rather than yellow. There's an informal and unofficial color code for NM cable: #14 is white, #12 yellow, #10 orange, and larger is black.
UF will work for your installation and would be legal, but it's pointless and very hard to handle. Save that for an outdoor project someday and get some NM cable!
mpoulton is offline   Reply With Quote
Old 06-05-2011, 07:40 AM   #8
If you are running a dedicated circuit (normally a home run), splicing in a junction box is still permitted, no?
Of course, if the UF cost you somewhat more then you might want to take it off and save it for an outdoor installation requiring UF and run interior Romex in its place.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 06-05-2011, 10:58 AM   #9
Thanks for all your replies. I got all the grey stuff switched out to the white. Wow! What a difference to work with. Now the inspector won't think I am an idiot. ;-)
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
ROMEX 14-2 wire from Canada Vs. ROMEX 14-2 wire from the U.S. Dazzlin Electrical 14 06-04-2010 08:51 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
