14 2 Black Wire To 14 2 White - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2009, 01:34 PM   #1
OneManJob
Post
14 2 black wire to 14 2 white
My house is older and has the old 14/2 (black) wire running through the house and I want to rig a 3 way switch. The only wire I can find is the 14/2 (white) wire.
The wires are the same guage and have two colours and a bare when you strip the casing off.
I am just wondering if the 14/2 black is the same as the 14/2 white or are they made to carry more amperage or something like that?
jeffmarleau is offline   Reply With Quote
Old 12-07-2009, 02:12 PM   #2
Rewards Points: 1,532
The wire itself is the same and carries the same number of amperes, but there are rules when you can use white versus black.
When using premade cables, sometimes the white wire is needed when connecting up a switch. A neutral is never connected to a switch terminal so a white wire on a switch terminal is not neutral. In that case the switched power (to the light, etc) goes on the black wire.
To connect 3 way switches, 3 conductor cable (14-3 on 15 amp circuits) is needed and preferably run directly from one switch to the other switch. Here use red and white for the travelers.
Put a band of red or black tape or stain on each end of a white wire connected to a switch.
For wires strung individually (through conduit) white is for neutral only.
Old 12-07-2009, 02:54 PM   #3
member
leoacrh's Avatar
the wire are the same, they don't use black for 14-2 they use white for 14-2, yellow for 12-2, orange for 10-2, and black for lower gauge wire ,you will need 14-3 for three way
leoacrh is offline   Reply With Quote
Switched receptacle wiring problem. sheshore Electrical 6 09-27-2009 01:37 PM
black wire on house a/c unit melted KEVIN17 HVAC 4 07-25-2009 04:43 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
3 wire to 4 wire question macmouse Electrical 24 05-01-2008 05:34 AM
