13W Max Fixture? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-26-2013, 09:32 AM   #16
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
You have to be careful using speed controls on the wall. Some will cause the fan to hum/oscillate. I prefer to just use the pull chain on the fan to set the speed. Switch the speed with the pull chain.
As for the lights....I'm surprised the bases are not GU24. Personally, I like the GU24's...but that is another story.
Try the CFL's with the dimmer...if they work...your good to go...if they don't....maybe consider LED. The costs have come way down recently. Even for the extra bucks....your going to like the fact that you will most likely never replace the bulbs in that fan again.
Old 05-26-2013, 09:37 AM   #17
Just call me Andrew
Rewards Points: 1,020
Are LEDs dimmable?
As for the fan, it doesnt hum at all, it works fine.
Andrew
secutanudu is offline   Reply With Quote
Old 05-26-2013, 11:16 AM   #18
Rewards Points: 1,192
You might want to look at a remote control for operation.
bobelectric is offline   Reply With Quote
Old 05-26-2013, 07:49 PM   #19
Rewards Points: 1,548
Originally Posted by stickboy1375 View Post
They probably are, but who knows if the trims are, at the end of the day, if something happens, you know where the blame starts.
Imagine the surprise after, having used 60 watt incandescent lamps, you enter the room to find that the little arms that held the lamp sockets under the fan blades have melted and sagged from the heat because they were made of plastic with a metallized coating.
I first ran into plastic with a metallized coating when building plastic model airplanes and cars. Nowadays they make faucets that way.
Old 05-26-2013, 10:28 PM   #20
Electrical Enthusiast
Rewards Points: 504
Kyle_in_rure is offline   Reply With Quote
Old 05-26-2013, 11:34 PM   #21
Rewards Points: 192
Most LEDs are dimmable.
bcgfdc3 is offline   Reply With Quote
Old 05-27-2013, 10:54 AM   #22
Rewards Points: 332
I'd just like to add that newer fans also have a limiter for the lights that cause the lights to not come on if higher wattage bulbs are installed.
sgip2000 is offline   Reply With Quote
Old 05-27-2013, 01:05 PM   #23
Oso954's Avatar
Rewards Points: 1,654
I have never see one that shuts the lights off completely(if working properly). Every wattage limiter I've seen acts similar to a dimmer, limiting the lights to about 190 watts. If it is shutting off your lights, the wattage limiter probably needs replacing.
Oso954 is online now   Reply With Quote
Old 05-27-2013, 10:07 PM   #24
Just call me Andrew
So we tried dimmable CFLs. Horrible buzzing, they turn off when the dimmer is about halfway.
I think we're gonna just return the fan and get one that has incandescent sockets. What a pain in the neck.
Andrew
Old 05-27-2013, 10:21 PM   #25
Rewards Points: 504
I would consider LEDs. Like others have said, they are usually fully dimmable, and you will probably never have to change the bulbs again
Ceiling light fixture wiring eveready Electrical 2 03-10-2013 10:55 AM
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 02:37 PM
Hanging an overhead fixture jbcurrier Electrical 8 11-25-2010 11:19 AM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 05:25 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
