12vdc 240vac In Same Outdoor Weatherproof Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 06:06 AM   #1
12vdc 240vac in same outdoor weatherproof junction box
We have (2) 2" plastic conduits buried from the garage to the back of the house. Where the 2 conduits come out of the ground, they go into a 8x8" weathertight junction box on the rear of the house.
1 conduit has 220vac
1 conduit has 3 siamese cables for security cameras and 1 cat5 phone wire
The siamese cables have 12vDC running through them.
My question is: Is this code to have both 12vDC and cat5 phone wire and 240vAC in the same junction box, even though they are run in separate conduits, or should each be in their own separate box ?
The holes are not run into the house yet for the wires, but I assume separate holes should be run for the 220v and 12v to enter the home from the outside weatherproof box.
ron351 is offline   Reply With Quote
Old 07-28-2011, 06:36 AM   #2
They should be separated. Low voltage control signals will pick up energy from the AC line.
The Following User Says Thank You to Just Bill For This Useful Post:
ron351 (07-28-2011)
Old 07-28-2011, 07:04 AM   #3
Licensed electrician
Rewards Points: 1,502
If the box were fitted with a divider to keep separation between the two voltage level it would be possible. I have never seen a 2 gang WP box that had the option for the divider to be added.
Use two holes at the house for the wiring. I would use an LB to go into the house instead of that huge junction box.
ron351 (07-28-2011)
Old 07-28-2011, 11:16 AM   #4
Thanks for the replies.
My bro n law will have to seperate the box some how.
I wasn't sure if this would be code or pass inspection if it came to that.
I thought 12vDC should be run in separate boxes and not combined all in 1 box with house current wires.
Garage feeder junction box bonding WillK Electrical 0 06-05-2011 10:03 AM
grounding old 2 wire junction to grounded junction gm8075 Electrical 3 03-28-2011 11:46 AM
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 02:37 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
