12v wires run with 120v yes, no!?
Hi I thought saw, read, heard that you can't run 12v low voltage wire in same conduit along with 120V wire. If that is true is it also true for snaking wires trough walls? Are we allowed to bundle up 12v low voltage wires with 120v wires and run them together throught walls or must a distance be kept to keep them seperated? I'm adding a couple of 20A circuits to house wiring and also need to put in speaker wire, security wire, bell cord, and low voltage wires in certain areas of the house and just wondered if there was a problem with using the holes for the house wires and the low voltage? I'm thinking not acceptable but asking the experts.
thanks
Walt
