12V transformer issue
I think I see what you are trying to describe: The two "black" wires appear to be two conductor lamp cord, thereby the insulation on both wires are black. The other cord just happens to have two conductors also and the insulation is white on both wires. Usually on a 110 volt supply like this it really doesn't matter which wire is the "hot" wire, but it may matter in this case, if your transformer calls for a "hot feed" connection. Look at the two black insulated wires closely, is one of them somewhat smooth, and the other has maybe "ribs" running along the length of the wire? If so, I believe the one with the ribs will be the neutral wire and the smooth wire the "HOT" wire, (someone back me on this). You will just have to know which prong on the male plug it "HOT" and which is neutral and wire it correctly. Good Luck, David
